John K - thanks for being a sport, as for blending it can be for th reasons cited already. Or for various oter reasons. For mild winter months maybe you just want to tweak the viscosity index by adding a small amount of pure synthetic to a high grade conventional oil, etc.
The smaller the sump size the less mixing becomes practical I think, but when you start dealing with 3.5 gal sump changes, blending becomes much easier, especially when you don't intend on running much more than normal OCI's.
Houndog, i have horses too, and ussually I have a base feed that they get but sometimes if i want to add weight, target coat or hoof quality,or adding muscle tone, I might add low dose supplemental feed for periods until target qualities are achieved. I have found Envision to be a really excellent all -round supplement in this regard. Also in winter I will often supplement the normal coastal hay with good quality alfalfa. Also different parts of the country are lacking in different minerals which while may be made up for in the normal grain mix, the added supplemental may not always be in that great of a bio-available form, or there may still be certain trace elements missing. Therefore switching feed sources from time to time may help cover deficencies from any one source. For instance in the SE US the soils tend to be highly depleted in selenium and other elements, so hopefully you are feeding to offset those defficencies in the forage. Grasses in your area are probably better in many respects to the normal coastal bermuda we have here as well, while I really like the coastal as forage, it does not have as many varied elements as many bent grasses, fescues, etc. So supplementation becomes even more important. Naturally these animals would vary thier diet over the course of the year in the wild by moving from area to area to do this on thier own.
