Never seen one of those Deeres, from front kinda looks like a Snapper knock off...
Originally Posted By: old1
Originally Posted By: jhellwig
Does anyone know off hand what the transmission uses for fluid on the snapper. I can't find a manual online.
Technically the snapper transmission uses "OO" grease. Not something you are generally going to find at wally world or even most auto parts stores. Snapper dealers have it, and aftermarket may have it in small squeeze tubes. Smitty's also has it. It has heavier viscosity than gear oil, but thinner than gun grease.
It's roughly the consistency of ketchup, will kinda ooze... Bought some when I overhauled the trans on the one I mounted Honda engine onto... One of my local hardware stores stocks it, I believe it's Sterns brand...
BTW on all I've seen that were 25 or so years old the grease had mostly dried out, def a good idea to get some fresh in it... Doesn't need to be full(in fact will leak), procedure to check is push handle to ground and fill till it dribbles out, will be approx 3/4 full at that point...
