Well. This DID NOT go as planed... in the least
I have a personal Husky 22 inch AWD mower with the 6.75 B&S 190CC quantum engine that I am sure lived a HARD life in the past with some serious hours on said machine. The 6.75 uses zero oil, but sounds like something is lightly "knocking" or "ticking" inside the engine at certain RPMS. Sound has never gotten worse over the years, and it always starts and never smokes.
I absolutely love the husky AWD setup because "hills" (Up up state NY
) even if the mower weights almost 100 lbs, it does not feel like it most of the time haha.
The plan "was" going to do an engine swap on the Husky. I jumped on Marketplace and found a 22 inch Toro Recycler 7.25 190CC non runner but garage kept push mower. The toro only had a few seasons total worth of use and then the owners could not get it started a few years ago and bought a ride on. Fast forward a few years that push mower ends up on Marketplace for $40 and I pick it it up & bring it home with the intention of swapping the engine over to the Husky. The Genuine air filter was completely clogged, and it looked like the owners replaced the spark plug with NGK to try and get it going and gave up. I drain the white cloudy fuel, give the carb a cleaning, gap the plug, and tighten every bolt. The headbolts I could almost unscrew with my hand. Replace the air filter, and change the dark/used oil, filled the tank with premium E-0, and gave it a pull. 2nd pulls it fires up & sounds really healthy with a nice smoke show from the many years of sitting. The smoke cleared up and I decided to "Try it out" What I noticed right away its alot lighter if only RWD but I can "swing" it around easier..
I like the Toro almost instantly and feel bad about parting it out for the Husky. I said "NO PROBLEM" I will just look for another parts mower with the Quantum series engine. Back on marketplace and I see listed is the "new" version of my personal Husky mower with the 7.25 190CC engine.. It's again a non runner for a couple years, but garaged kept machine. And again the owners bought it brand new a few years ago, used it a few times on their postal stamp size lawn and again could not get it started in the spring so they just hired a lawn guy to handle it. It sat in garage for a couple years, until the owners could not even fit the car in garage, so they listed it for $75 just to get it gone. long story short there, I pick it up bring it home and do my routine. Again the fuel is very white cloudy with like a slime? in bottom of carb bowl.. change oil, tighten all bolts, clean carb and tank check gap on plug ect, 2 pulls later she fires up, and it did not even smoke..
Now I am up to push mower number three. When all I was looking for was a "parts" mower to keep the "OG" husky awd going. Unfortunately it is looking like the "OG" is going to be retired and used for parts to keep the other two mowers going.
I really like the older style "L" / Flathead B&S engines. They are extremely bulletproof and seem to run forever on sometimes the original oil for a decade or more. Most can also fix a flathead with the most basic Walmart tool set and keep it going for many years. I've read because EPA ect, the "L" head had to be retired for OHV design around mid 2015? That also seems to be around the same time "just add oil" never change system" appeared. While the newer OHV engines are a little smoother, a little more efficient, and even a little more "powerful" under certain conditions I do not believe they will last anywhere near as long as a good ol flathead, just because of the "Never change oil" and cheaper components. I still change the oil on a OHV never change system for a couple clients - just tip it on its side and drain out when warm, and what I have noticed that oil comes out much darker and even appears "thinner" like the OHV design is "harder" on the oil. This is just an observation.
But here they are and I am staying off of marketplace for a little while.
