I've been trying to learn a little bit about aviation oil, and here's what I've come up with. Aviation piston engine oil contains no metal based additives, and there are both ashless dispersant and non dispersant oils. Most available are mineral, with exception to oils like aeroshell 15w50.
Ok. So if any of that is incorrect please dont hesitate to correct me, because that's about all I can find.
Here is my question; why dont vintage auto enthusiast use aviation oil instead of "classic car oil". Why dont we use aviation oil in compressor pumps in hot climates? It seems to me that aviation oil is low or no detergent, much like classic car oil and compressor oil, and it seems it cools almost better than in lubricates. Moreover, the aviation oil isn't any more expensive that classic car oil and there are plenty of online vendors for it, plus most small airports sell it. Given that the zinc issue doesn't really apply to most classic cars with standard camshafts, why isn't this a thing? These guys usually change the oil pretty often anyway, so what's the disadvantage?
What vehicle and what engine is your classic car?
Why would one use an aviation piston oil when there are classic car oils formulated specifically for those classic cars?
A common misconception is that aviation oils are somehow superior in some way to terrestrial water-cooled engine oils and this is not the case.
An aviation piston engine oil has approx. 250 ppm of phosphate anti-wear, about 90 ppm of calcium as a mild detergent, about 5 ppm of ZDDP which acts as a secondary anti-oxidant. about 5 ppm of sodium as an anti-rust agent, and an ashless dispersant; so they are not completely ashless. The low treatment levels of organometallic elements keeps ash and deposits at a minimum.
Lead loading of aviation piston engine oils is around 185 ppm of lead per hour of operation, and this is where most organometallic deposits come from.
Aviation piston engine oils usually derive their anti-wear and anti-scuff capabilities by virtue of a high viscosity oil film and the phosphate additive.
Terrestrial water-cooled engine oils need about 3.5X that amount of phosphate anti-wear because of the reduced oil film thickness in lower viscosity oils.
As another poster stated, these air-cooled engines go through some wild swings in terms of temperature fluctuations whereas a terrestrial water-cooled engine maintains an almost constant temperature after warm-up.
Bottom line is, it is not recommended that you use aviation piston engine oils in any terrestrial machine.
