Honda HCF-2 Change Frequency and Alternatives
2022 Civic CVT here, how often should the fluid get drained and filled? I know you only get 1/3-1/2 of the fluid out at any given time anyway, and my driving habits are pretty tame, but was thinking to do the first service around 30k miles and then run with 30k mile increments. The fluid seems fairly inexpensive and the job is easy to complete.
Also curious to hear some alternatives for the HCF-2 though I'm not particularly fond of the idea of mixing some third party fluid with whatever is left over in the CVT of the factory fill, and tend to trust the Honda branded stuff a bit more overall
I used Valvoline Maxlife ATF on my last drain and fill in my 2018 CRV. It is listed as being compatible with HCF2, and from the research I did before buying the Maxlife I read that it's fully synthetic, where Honda's version might not be, so in my mind it might even be better.
I would stick to Honda OEM fluid...IMO
You don't need to go to the dealer for CVT fluid.
Valvoline cvt fluid is good stuff. Amalie also makes good cvt fluid.
I used the Amalie in a 2013 Accord with no problem. Autozone and AAP house brand cvt fluid is Amalie.
For the interval, change it when the minder says to :)
Play it safe and stick to OEM Honda fluid for your CVT...
I did a single drain and fill in my 2017 Accord Sport cvt shortly after I bought it used with a little over 29K miles on it, started researching alternative fluids and went with Amsoil CVT fluid.
I think around the 32K mile mark I did a 3X drain/fill with Amsoil cvt fluid with around a 15 mile drive in between. Around 30K miles later did a single d/f with Amsoil again. Have just over 72K miles on car now, still runs like it did when I first bought it.
I’m sure I would have been just fine sticking with the made for Honda hcf-2 fluid, but I wanted a supposedly better fluid.
I use Castrol transmax cvt fluid in her 2015 Altima.
It would have been probably easier to just use a readily available cvt fluid from auto parts store but I’m ok with having to preorder the Amsoil fluid when I know I’m getting ready for a drain and fill
I did a uoa on the the single d/f and Blackstone said I could go 35K or further but I’m sticking with Molakules recommendation of 25-30K mile intervals as he has stated that cvt’s shear the fluid worse that step shift trannys
What was “better” about the Amsoil stuff? I agree on the interval, 30k is a good one IMO
keep it changed, especially in Acura/Honda.
Does HPL offer anything compatible? If they do it isn't exactly leaping out at me from their website. If I've read this thread correctly it seems to come down to the OEM fluid vs. Valvoline.
Stick to OEM Honda fluid for your CVT....
HPL offers a CVT fluid. I may give it a try once I am out of HCF-2. It's a at the advlubrication site under ATF.
I like these comments like I may give it a try or it may work or it should not cause any issues or try it and if it does not work go back to OEM.... I will not take a chance and stick to OEM Honda CVT fluid and not guess if it MAY WORK or NOT....Thats just my opinion...
Well you have all these posts on here and other sites with people using non oem fluid and their cvt is running just fine. You are entitled to do what you like as are others but don’t you think we would be hearing about failures if non oem fluid was bad? I’m sure you know Honda doesn’t “make or blend” their HCF-2 ‘branded’ cvt fluid, it’s blended to their specifications. Do you use Honda branded oil too to not guess if it will keep your motor running
Its blended to there specs...You are right but some fluids say that they can be used in a list of trannys..that not for me...I will use only OEM CVT fluid in my Honda...The OEM fluids I use on my Honda are for the CVT...AWD rear dif and coolant...I use Mobil 1 for motor oil and a FRAM filter...It works for me...My past hondas have gone to around 400000 miles doing it that way and I aint going to stop now...I respect your opinion...but my real world track record on my past Hondas ...I see NO reason to take a chance...
