Originally Posted By: ArrestMeRedZ
Originally Posted By: Ursae_Majoris
40 S&W. Recoil is not much more than 9 mm, magazine capacity almost as high as 9mm, kinetic energy is the same 45 ACP.
G23 will double as home defense and concealed carry.
I also thought that, until I looked up the [reloading] specs of the S&W 40. The kinetic energy is significantly lower than a .45. That being said, there are other considerations that indicate it is an adequate round for self defense.
Taking numbers from the post above:
9mm 124 @ 1181 fps is 12,354 ft^2/lbs
9mm 147 @1032 fps is 11,183 ft^2/lbs
40 S&W 165 @ 1076 fps is 13,645 ft^2/lbs
40 S&W 180 @ 995 fps is 12,729 ft^2/lbs
45 ACP 230 @ 875 fps is 12,578, ft^2/lbs
165 grain 40 S&W is a clear winner as far as kinetic energy is concerned(among calibers we are discussing; 357 Sig is the overall winner with 15,534 ft^2/lbs).
I have pushed 125 grain Nosler JHPs with Blue Dot and Universal Clays well past 12,000 fps in my reloads out of G22 (still very safe, no bulging, no 6 o'clock Glock smiles). Sorry do not remember exact numbers.
I do not know what manual you have used, but I have Lyman 47th, Nosler (x2) and Speer. They show similar data.
BTW formula for kinetic energy is mv^2/2.
To translate bullet weight into pounds, divide by 7000 first. There are 7000 grains in a pound.
