Highest flowing oil filter for 13/16-16 or 3/4-16 thread
eastern NewMexico
I'm looking for the all time highest flowing oil filter, the filtration efficiency doesn't even need to be worthy of being called a rock catcher.
I'm thinking something like a full flow "race filter" that's just a trash screen that may barely even stop 100 microns would be great.
I have seen "filter blanks" and "test filters" that contain no media even those would be fine.
But I have not been able to locate either type.
Anyone know where to get something like that?
Purolator Boss PBL20195 or the PH8A crossref version if you have extra room for a fatter filter.
Donaldson DBL0832 for the largest, fattest filter if your bypass spring is built into the block.
Wix racing oil filter: https://www2.wixfilters.com/Speciality/Racing.aspx?1
The filters that had the lowest dP in Brand Ranks' testing were the Purolator BOSS, WIX XP, NAPA Platinum, and Baldwin.
Whichever of those you can find in the largest size that will fit would be a good bet. Baldwin and Donaldson might be your best bet for huge oil filters. There are also the FRAM Racing HP1 through HP5 models that are large and should have low restriction.
Gravity transfer diesel tank. I just want a filter that's barely even a filter to catch water that's already settled out in the bottom of the stainless steel tank.
shouldn’t you be looking for a fuel/water separator filter combo?
Here's what you need...
https://www.amazon.com/Replacement-...J8C1?source=ps-sl-shoppingads-lpcontext&psc=1
