This is what I’m putting in my 3.5 EcoBoost, as well.I just ordered No-VII 5w30 Euro for my Durango (3.6 V6). I'm more curious about how you think that one is blended, because the specs are unbelievable, all around.
The only reason why I can think of is if you have an engine that's known to burn oil, then you should probably pick the PCMO because of lower SAPS. Other than that, absolutely no reason. Since all of their oils contain high amounts of Moly and the detergent formulation is a mix of Calcium and Magnesium, LSPI is a non-issue with either oil.When talking 5w30 is there any reason to use the PCMO over the Euro?
Actually this oil can handle combustion byproducts and contaminants like no other. Combined with the excellent cleaning abilities and superior lubricity (above most motor oils), you can do extended OCIs with it, provided that your sump is not micro-sized and you're willing to change your filter once in a while. If your sump is small, I would do a filter change every 5K miles, and maybe go 15K, depending on your idling time. I haven't yet decided how I'm going to proceed from here on out. For now I'm thinking yearly oil changes, which is about 7K~8K per year/vehicle for me. So no in-between filter changes. I'm probably throwing away good oil at that point, however, I need these vehicles to last us for a very long time and won't cheap out on oil, for sure. Each of our vehicles takes on 6 quarts, so there is that. In the Hyundai I can put in 7, but that's because the folks who wrote the owner's manual were probably Liberal Arts students.I gotcha, it will be going in my 22 Tacoma so this oil is overkill for this truck. Been wanting to switch to 10k OCI, now just gotta decide what filter to pair it with.
You have a 9.2 quart sump. It can probably hold 10 quarts without any issues. Yeah, with this oil, and that big of a sump, you can easily go over 10K miles on a OCI, probably on one filter if it's not a tiny one.Thanks for this info. I am still on the fence about 10K OCI's. I know they are fine to do, but I don't mind changing the oil/filter.
Edit: Just did the math on about how many miles per year i would do, and its very low. Under 10k easily. Now I like the 10K OCI's even more now.
Did you even lookup the oil capacity for a 22 Tacoma before commenting?You have a 9.2 quart sump. It can probably hold 10 quarts without any issues. Yeah, with this oil, and that big of a sump, you can easily go over 10K miles on a OCI, probably on one filter if it's not a tiny one.
6.2 is what I see for both engine options.You have a 9.2 quart sump. It can probably hold 10 quarts without any issues. Yeah, with this oil, and that big of a sump, you can easily go over 10K miles on a OCI, probably on one filter if it's not a tiny one.
You're right. I misread the capacity by reading it from the next page (coolant) on my phone. Small screen, and the "coolant" part was rolled up.Did you even lookup the oil capacity for a 22 Tacoma before commenting?
I ordered the 10w20 for my Mazda. My thought was narrow spread would be good for resisting degradation from fuel dilution. Not that cold here, would be slightly thicker cold when diluted with fuel, than the 5/20 would be.This Euro 5W20 checks a lot of boxes for me - good cold temp performance, strong HT/HS (better than most 5w30's) and excellent shear stability.
What does one gain by choosing the Euro 10W20 over the Euro 5W20?
No, fuel is simple dilution of viscosity here. Enough dilution and it will go out of grade like any other oil.I ordered the 10w20 for my Mazda. My thought was narrow spread would be good for resisting degradation from fuel dilution. Not that cold here, would be slightly thicker cold when diluted with fuel, than the 5/20 would be.
Yes, that's what I meant. Repeated dilution and boil off ( distillation if you will) not degrading the oil.No, fuel is simple dilution of viscosity here. Enough dilution and it will go out of grade like any other oil.
Yes it will help with permanent or temporary degradation of the VII since there aren’t any, but the greatest contributor to viscosity loss is just the fuel itself.
Exactly what @High Performance Lubricants relayed to me. Bravo, sirThe only reason why I can think of is if you have an engine that's known to burn oil, then you should probably pick the PCMO because of lower SAPS. Other than that, absolutely no reason. Since all of their oils contain high amounts of Moly and the detergent formulation is a mix of Calcium and Magnesium, LSPI is a non-issue with either oil.
It will degrade it, but slower than it would most other oils.Yes, that's what I meant. Repeated dilution and boil off ( distillation if you will) not degrading the oil.
It will dilute it but how will it degrade it?It will degrade it, but slower than it would most other oils.
Here's a good example of how HPL no-VII stands up to fuel dilution:
My question has always been , and I asked at the open house; how does repeated fuel dilution boil off affect the oil? What gets left behind from the fuel distillation?It will dilute it but how will it degrade it?
So they never completely answered your question?My question has always been , and I asked at the open house; how does repeated fuel dilution boil off affect the oil? What gets left behind from the fuel distillation?
The HPL panel stated that fuel dilution reduces the effectiveness of the zddp. But what from the fuel is left behind after boil off ? And how does that affect the oil?
