- Joined
- Nov 29, 2021
- Messages
- 5,383
The first engine oil filter that was on 100% after adding the product has been cut open.I would certainly not expect there is anything absolute you can hang your hat on. If you had a reference sample as soon as the cleaner we would look for some things based on what we would expect out of the deposits. The deposits can put a dent in TBN, deposits can contain wear metals the would result as a quick increase of wear but rather would be material released back in suspension. And of course general increase in sludgy nature of the oil such as Mr Mola has seen. The converse TIGeo, he is seeing clean oil and not a lot of difference. Esters clean. The fact that his remains clean is certainly an indication that his hot rod is pretty clean already.
David
TL;DR is, 53' Stude states the oil looked kind of rough, but filter good.
This brings up the question again that things may have been somewhat clean already, but the EC may have been responsible for the oil looking kind of rough.
I would absolutely buy more of this product.
https://bobistheoilguy.com/forums/threads/super-tech-6607-cut-open.350480/
