High Performance Lubricants Engine Cleaner
I would certainly not expect there is anything absolute you can hang your hat on. If you had a reference sample as soon as the cleaner we would look for some things based on what we would expect out of the deposits. The deposits can put a dent in TBN, deposits can contain wear metals the would result as a quick increase of wear but rather would be material released back in suspension. And of course general increase in sludgy nature of the oil such as Mr Mola has seen. The converse TIGeo, he is seeing clean oil and not a lot of difference. Esters clean. The fact that his remains clean is certainly an indication that his hot rod is pretty clean already.
David
The first engine oil filter that was on 100% after adding the product has been cut open.
TL;DR is, 53' Stude states the oil looked kind of rough, but filter good.
This brings up the question again that things may have been somewhat clean already, but the EC may have been responsible for the oil looking kind of rough.
I would absolutely buy more of this product.
https://bobistheoilguy.com/forums/threads/super-tech-6607-cut-open.350480/
So, the POS in the background is due for an OCI in ~400 miles. It’ll see a mix of
1 qt mixed VSML + ST FSHM 5W-30
1 qt of ST FS 5W-30
1 qt of HPLEC
.4qt of Castrol Edge Bio-Synthetic 5W-30
Remainder to be however much cheap 5W-30 Formula Shell 5W-30 I left over from a post-piston soak oil change to make up 3.7-3.8qts. Haven’t decided on a filter. More than likely a Fram OCOJ or ST. I do have an OEM Toyota filter but not this time.
1 qt of ST FS 5W-30
1 qt of HPLEC
How long are you planning on running this fill?
As it's somewhat related and if anyone is interested...here were my LM flush before/after results and Blackstone's commentary. It's the 2 furthest left columns.
Thanks for posting this.
I imagine the VW you used in this in was very well maintained in the first place so maybe there wasn't much cleaning to be performed. Great report considering. Even the flashpoint isnt that low considering.
If so I'll need the route map/live sat tracking.
@schwinney will be a great co driver for your journey.
Yes, this one is v. well maintained for sure.
I will admit, a position on the road would be perfect for me.
I may be picking up more EC soon. Figuring out the details now.
I put 1/2 qt in 350z for the last 2k on current oci.
Also put 1/2 qt in jetta gli for last 1.5k on 6k oci.... next 1/2 on last 1.5k on next oci.
Next up is my k24 accord oil burner but its only 1k into oci.
I ordered 2 qts for the 3 cars.
My thoughts are its dark colored and pours like a 10w40 lol.
This company is truly a top notch class act.
Look what Dave (President, CEO, HPL) gifted me today for visiting.. not a usual occurrence I am sure but I feel I am a special case in a good way so they gave me a case! :D
Anyone that leaves New Jersey in the evening and drives all night overnight to be at our plant to meet my availability deserves a reward. That is some kind of dedication.
