High Performance Lubricants BAS 5w-30 Racing Oil VOA
Originally Posted by SubieRubyRoo
Originally Posted by Bailes1992
I always thought that anything more than 100ppm of Moly was a waste?
I'm pretty sure I remember reading in a research paper posted on here a while back that moly really doesn't start to show real friction reduction benefits until it is OVER 200 ppm. There were a couple other "benefits" to higher moly... as long as the base oil will keep it in suspension.
I believe that's for "conventional" moly. Tri-nuclear requires a significantly lower treat rate for the same level of effectiveness.
Originally Posted by RDY4WAR
Originally Posted by 53' Stude
Thank You RDY4WAR
I found it at Advanced Lubrication Inc. They sell it in 12 quart cases only for $164.34 (plus tax and shipping) which comes out to about $13.70/qt.
815-932-3288
Thank You kindly RDY4WAR
I thought it was the other way around. Lower doses give you friction modification, while the very high doses will also provide anti-wear. Don't mind me, though, since I haven't used an oil with any moly in the better part of a decade.
This is an oil that we are looking into for our race cars.
Does anyone know where 14 ppm of nickel would come from in a virgin oil sample? What about the vanadium and barium?
The base oil is a blend of 1-decene, homopolymer PAO and 1-decene, trimer PAO. The ZDDP is short-chained secondary type. The moly is all tri-nuclear.
Let me know what you think.
EDIT: The VOA seems difficult to read on here when loaded. Here's the data.
Iron: 0
Chromium: 1
Nickel: 14
Aluminum: 0
Copper: 3
Lead: 0
Tin: 0
Cadmium: 0
Silver: 0
Vanadium: 4
Silicon: 23
Sodium: 17
Potassium: 0
Titanium: 0
Molybdenum: 1747
Antimony: 0
Manganese: 0
Lithium: 0
Boron: 118
Magnesium: 4
Calcium: 2488
Barium: 8
Phosphorus: 790
Zinc: 947
KV100 = 10.2 cSt
TBN = 8.72
Oxidation = 11
Nitration = 5
This is a VIRGIN oil sample, not used. OAI screwed that up so ignore the comments.
Can this specific 5w30 be used in V8 trucks.
They make a much more appropriate 5W30 for street driven vehicles.
@High Performance Lubricants makes great oil. I’m running their 0W30 in one of the Volvos and will change the other cars over in time.
Take a look at Wayne’s results in his Durango, in this thread.
The silicon is for anti-foaming. I'm not worried about that. I actually want that there.
More than 100 ppm of moly may not show any gains for a daily commuter cruising along at 2000 rpm. The engine this oil is going in is a big block V8 making 1300+ horsepower at 9000 rpm in a highly competitive racing class. We'll take any edge we can get. The margin of victories often come down to thousandths of a second.
Maybe I am forgetting, but I thought the anti-foaming agent was silicone , not silicon . But if you break down silicone you get the element silicon . So how is one supposed to tell the difference between something good like silicone, vs something bad like silicon from dirt ?
You can't from an oil analysis. That's why it's important to know what is in the oil before use.
