Originally Posted By: Johnny2Bad
Nylon has been used on Timing chain gears by all the domestic automakers since the 1970's.
Polymers are now used in structural areas (eg: intake manifolds). Good enough for handguns, must be good enough for Honda.
Most (almost all) plastics are made from oil.
I don't see an issue; if there were, well, they've had about 40 years to figure it out.
Actually since the '60s, they were failing in the '70s and AFAIK nylon toothed timing gears were discontinued in the '80s... I've never replaced one with anything but steel...
Now there are all sorts of stories about failed plastic chain guides and intakes, so nope in 40 years they haven't got it right... It's no fault of the oil, when these materials are subjected to continual heat/cool and or wear cycles they fail...
