I'm using a 0w-40 with ZERO moly. What is this fascination with moly? It's not the only AW/FM out there nor has it been in any way proven to have ANY impact on noise in this engine.
Most HEMI engines that tick have leaking exhaust manifolds, that was the case for EVERY SINGLE ONE of our trucks at work. ALL of them that made noise. That's not to be confused to a start-up rattle or quick clatter that goes away.
I think mostly because RedLine has quieted ticking engines (the ticks not being exhaust manifold related), and the biggest thing that stands out in RedLine vs others it the amount of moly and the "weight" of the oil. Im sure there are other differences, but without getting proprietary secrets, the only thing to go on is a used oil analysis or VOA.
FWIW my experience with it echoed others....definitely the quietest my Hemi has run. I know PUP is supposed to have a good moly level, granted its the tri-nuke stuff so its "lower" on paper, but for some reason PUP was not nearly as quiet. Both were 5w30 but RL is a much heavier 30.
Its weird but its almost like the Hemi responds better to organic moly than the new stuff. Maybe just a big coincidence but my experience plays out the same (PYB was quiet as well, with its ~187ppm of moly...numbers like that usually indicate organic)
