why not drive to the roundabout at the end of your street (post #18) and burn rubber?
Tell the neighbors and police you are fixing the hemi tick and they'll understand.
So what's the solution/conclusion on the Ram website? Thicker oil with moly ... or is it a never ending discussion?
The biggest hangup is "what is hemi tick?'
There are 3 that I know of: one is the loud knock type noise that I hear in a specific situation, one is broken exhaust manifold bolts and the third is some form of lifter tick.
The loud knock type noise I know how to avoid so I dont ever hear it.
The broken exhaust manifold bolts are common, but I have never had it happen (yet). It seems the biggest indicator of those is that the noise will go away after a certain amount of run time (think minutes, not seconds)
Some form of lifter tick - well, every vehicle I own has some form of lifter tick at startup. My old Frontier would tick for 30 seconds on every dang startup....new oil, old oil, sat overnight, sat for 10 minutes. It didnt matter. My Hemi actually makes less lifter noise at startup than the Frontier. Is it a bit noisier while running? Yes, probably. Ive had various levels of "loud" while running depending on the oil used. PYB was one of the quietest, but with short trips and cold weather, I prefer a synthetic. PUP was one of the LOUDEST, which was unexpected. RedLine was the quietest, but I drive the truck 6K miles per year....Id rather change the oil twice a year and use something less expensive and easier to obtain. QSUD seems to be working out well, but hard to tell 100% because I dont drive with the windows down when its 20 outside
Note that I run 5W-30 just because I feel better about the heavier weight. I know thats a huge debate in itself, but all the research Ive seen indicates there were no changes to the engine between 2016 and 2017 (I have a 2017)....if you read the 2016 manual, it says 5W-30 is allowed/acceptable. The 2017 manual does not have that note....but if the engine didnt change, somehow I think it will be just fine. With how warm (hot?) FCA seems to have set the truck to run, I figure Im better protected with slightly heavier oil at the 215 degrees it seems to like to run at.
