I bought a 2001 Cavalier about a month ago from a small dealership. I brought it home and changed the oil. When I took the drain plug out I noticed some material on the magnetic plug. It was very fine and was gray when wiped onto a paper towel. When I finally got the oil filter off (took a while) there was some gasket material still on the engine that I had to scrape off with a razor blade. I guess that on there for quite some time. The oil itself didn't look that bad. I did a car fax on the car and it appears that it sat for about a year. I just changed the oil again today and send a sample to be analized at Blackstone. Again there was material on the drain plug. There was some brown shiney particals coming out of oil filter when I dumped it out. There was also the same particals on the end of the dip stick when I pulled it out to check the level. The oil itself looks clean.
The car had 79600 miles on it when I bought it. I ran the Supertec 5-30 oil and Fram filter for 1749 miles as I wanted to get a sample. The coolant level has been steady and there are no oil leaks. It didn't burn any oil either.
The engine runs fine, is not noisey and is getting 31 mpg. I changed the air filter when I did the first oil change.
So am I screwed????
So am I screwed????
