- Joined
- May 5, 2018
- Messages
- 27,654
This one is probably 7 years old or so. The silicone adbv moved it up market to me. I cut a Baldwin version that was a new fresh one. B7491.
Not fancy but solid and I can't believe the Baldwin version will be my Maverick hybrid choice for a few reasons. I wasn't a great fan for one.
The Silicone adbv took it out of the short run type of filters. The bypass valve seals off well and can not be forced off center like the K&N Silver featured earlier here. It is very robust and well guided and has no play in it.
The can is a few thousands thicker than most and excess glue residue is not a big issue here and the latest Baldwin had none.
This Hastings clone had tighter louvers but the Balwin are now bigger for better flow in the B7491.
Both the Hastings and Baldwin had a perfectly round can where the last Frams and K&N and others were out of round. Is that an issue...probably not but you don't get any wobble with these in a filter cutter. Just one more thing in their favor. The coil spring has no sharp edges and is very robust.
With Zoro your talking a bit over $5 each using the cart 20% discount and shipping is free after $50...
