Harley RKC 103... changed exclusively to Redline!
Denver, CO
Got the 2011 Road King Classic 103 in January 2011 and in-between the snow, ice, rain and abundant sunshine of Colorado, have managed to put on just about 6,000 miles on the bike.
Changed the three holes to Mobil V-Twin 20W-50 (engine) at 800 miles along with Primary and Transmission (Shockproof) to V-Twin Redline Synthetics.
At 2500 miles, changed out the engine oil to Mobil V-Twin 20W-50.
At 5,000 miles, changed out all three holes (will go 5,000 miles from now on) to all Redline oils... V-Twin 20W-50 oil in the engine.
By changing from Mobil V-Twin to Redline, the engine is running smoother, sounding less like a sewing machine and more like a V-Twin. The loud ticking with the Mobil oil is a lot quieter with the Redline in the engine.
Mobil V-Twin and Redline both make excellent oils... this is a given!
From what I'm hearing, with 1,000 miles now on the engine with the Redline, the bike is running A LOT quieter.
As usual, YMMV!
Sounds like a well ridden and well cared-for bike to me.
Carry on.
Red line shockproof helped my transmission. It's less clunky and finding neutral is a breeze now. In spring and fall I run a 5w-50 then come summer a 50w. I put liqui-moly in the motor and it took a couple of tanks of gas before the idle dropped down to normal again and on my dipstick temp gauge after a freeway run it held steady at 230. It used to hit 260 when I tried mobil 1 v-twin in the motor. The liqui-moly has changed my mind about buying an oil cooler. I am changing my cams this winter. Then we will see if it helps wear too
Next oil change, for about the same price try Klotz synthetic, they have the engine oil, transmission fluid and primary. I have used Red Line also, very good oil but I seem to have better results with Klotz.
www.klotzlube.com
I have used Redline on all 3 holes for about 2 years now. Good results for me.
The Professor recommends Amsoil 20W-50 in the engine and the Primary. And the Amsoil 75W-110 gear lube in the transmission.
Thanks for asking! Worked OK although It seemed to be a little heavy and the engine seemed to run a little sluggish compared to the Klotz synthetic, so I switched back.
www.klotzlube.com
What are your better results? Please explain.
I'm always looking to run the best lubricants I can buy!
Sure, I run all Klotz products in my built 03 Harley softail. I have used all other leading synthetic's and with Klotz it just seemed to make my bike run smoother. Cold starts seem easier, fires quicker & my throttle response is better, sounds crazy but the engine just seems to rev easier. My engine is built, I have larger cams with head porting so my bike tends to have a little more valve train noise; using klotz the bike sounds nice, like it should. This is just my personal opinion, I am not a dealer or tying to say Klotz is the best, it just has proved to be better for my application. Give it a try, you will not be disappointed. Thanks.
See this is info I can relate to. A guy who rides his bike so knows every sound it makes and how it feels as well as knows how the throttle responds. I started with amsoil 20w50 and although I know for a fact it's a great product the valvetrain noise was insane. So then mobil 1. And the valvetrain noise was worse,then red-line and it sounded like a different bike. So red-line it is. Now your saying you have used it and klotz is better. Then this I gotta try. Thanks for posting.
