Hard To Read Dipsticks
You would think by now that car manufactures would have made the ideal Dipstick that can be accurately checked. My old Chevys oil dipstick is similiar to my Fords Tranny dipstick except it's flat black on the end.....which makes reading it alot easier. I guess I'm going to paint the Fords dipstick now.
My Porsche doesn’t even a have a dip stick.
Nissan's dipsticks aren't accurate, especially the 4th gen Maxima!
The old GM 2.2L pushrod dipstick is combined with the oil cap, so you can't even look in the engine from it :sneaky:
HAHA! Whenever I get a painted dipstick car, I sandblast the end. Want to see how clean the oil is.
I like when the dipstick is actually flat at the end rather than being twisted :D
My Jaguar doesn't even have a dipstick. The oil level is checked electronically. When I did my own oil & filter change I refilled it with exactly what the owners manual says is the capacity. The electronic reading, which is supposed to be taken with warm oil, 15 minutes after shutting down the engine read just below the maximum mark.
Then I let the dealer do an oil change. They over filled it causing a warning message on the readout. I told them to remove some oil.
I don't know how much they removed but probably too much. So I started adding 1/4 quart at a time and checking the readout.
Now when I check the oil I get the warning message that it is overfilled but it immediately turns off and I can see the level drop one graduation on the gauge and then another. So I am assuming that it is OK but why does the warning message come on for a second and then shut off ?
I sure wish it had a conventional dipstick. How much money would it have cost them to add one ?????
Much better to just rely on British electricals, given their historical reputation for quality and reliability.
Kia ones are pretty simple / basic but easy to read. The bottom of the dipstick is like a non-shiny metal while the rest is normal
have a friend who has a civic that I check the oil on, it has like an orange plastic dipstick on top of the motor, that one’s on the harder side to get a accurate reading you can get close enough though.
Just looked at the dipstick on our new Kia Soul and the very end of it is yellow plastic and very difficult to read - had to bring it outside the garage and hold it at an angle to the sun and even then I wasn't too sure.
A simple dip stick is far too primitive, simple, and reliable for the Germans, they love to way over engineer everything!
although if I'm not mistaken, Porsche was very late to the game in using a push to start button for the engine. My BMW too doesn't have a dipstick, and my Toyota product has none for the auto trans!
It is odd, our GM has two readings depending on which side of the dipstick. I go with the lower reading, really--it is consistently the side of the dipstick facing in. I just go with that and have for more than 10 years! :)
Maybe motor oils need to add dye so we can read dipsticks better? What was it, old Silkolene used to be green/blue oil....
The ones in the Safari isn't so much hard to read, it's hard to determine where the oil level is. This goes for both engine oil and transmission.
Both dipsticks are +3 feet long and when removed, it drags out what's on the stick and deposits in the tube. Wiping it off and re-sticking it, all you see is drag out. You have to look carefully to see where the oil level is (if at all).
Sometimes, I remove the sticks, wipe them and set them aside and go about doing something else for a while. I come back and then re-stick.
When I check the oil level I pull the dipstick, wipe clean with a paper towel, insert and pull out again. The paper towel is used as a backdrop while I hold the dipstick in the proper light.
Through all the years I’ve never had a problem using this method.
2nd gen Tacomas are notorious for smearing oil up into the dipstick tube, which makes the subsequent reading very difficult. I pull the stick and wipe it off, let everything sit for at least 10 minutes while the oil drains from the tube back to the pan, and then insert the stick for a reading. Also I used sandpaper to scuff up the shiny end of the dipstick which seems to help the reading, along with some daylight or a good shop light to see the reflection on the tip. Not supposed to be this hard LOL.
By far the absolute worst I've ever dealt with was what Toyota uses/used in the Corolla 1.8L. Family members had one from 2008 and 2014 and the only realistic way to check it was to park level and let it sit for hours or overnight. Removing the dipstick to wipe, then reinsert was a waste as it was such a tight fit oil would smear up/down the thing and never gave a correct quick reading.
Why go to better dipsticks just as ICE is phasing out?
