Yes. Or a garden sprayer.Could you rig up ten feet of 3/8" hose and a funnel from above?
You have a transmission that is LEAKING-some where. It's not normal. A normal transmission DOES NOT LEAK.
My 6R80 dipstick has hashed A and B marked areas on the dipstick for checking the fluid hot or cold so it doesn't need to be 200f, basically just running so all the fluid can be filled. I've drained and filled a number of times and always fill to the lower level with cold fluid which seems to work perfectly.I have been doing my daughters Edge. You can fill from the top vent. But you have to remove a plug on side of trans. Then heat fluid to about 195 degrees F. When it is heated to proper temp, and finished draining cap it.
I have 2 6R80 Ford vehicles that I use a funnel and hose, with curved metal tube going into the trans. It is on the slow side. I had an accident doing it on my F150. I had a piece of silicone tubing connecting the PCV tube to the funnel. I wrapped electrical tape around that area. When I was almost done with the job it popped off. Big mess with about a half qt trans fluid.
I am going to make a better set up for that job. Really fun on the F150, and Expedition with a catalytic converter right next to the trans. They require the fluid to be scalding hot to finalize fluid level. Of course with the engine running..... Nothing more fun than 200 degree fluid, and several hundred degree converter right next to my hand.
B&M is gouging for the dip sticks for sure.
I need to get the funnel set up perfected with a valve inline.
Yeah, no more often than you do a transmission - start with a new but cheap one - next, do a fence with water seal - served its purpose by then if seals give up …Yes. Or a garden sprayer.
I think they're working on it.What's next...no steering wheel?
2017 is old?All we have left that’s old school is the 2017 Tahoe … love it.
The other’s are goofy - worst being Lexus bcs they put the cat back system over the fill plug …
Subject is tube with a dipstick - that is old school har har har …2017 is old?
My newest is 10 years older.
The line is swollen-it will probably leak again.You must not have seen the part where I tightened the loose line up.
I only did it on the Tundra. I think Camry, their 6AT, I think there was a widget that could be used in the trans pan and set to the right height for oil temps that were not in the super small window. I was not crazy about the small temperature window but it was sorta easy. And on that transmission I didn't worry too much, as it wasn't known for failures--this was something that really only needed doing every 50k.After doing this a few times, I’ve really come to appreciate Toyota’s method more and more.
It's metal and a flare fitting.The line is swollen-it will probably leak again.
You have a transmission that is LEAKING-some where. It's not normal. A normal transmission DOES NOT LEAK. It's a sealed system. The fluid doesn't evaporate. It's has no where to go-assuming it's not leaking. A dipstick is not needed.
