2018 RAV4, 190k miles.
I had the transmission drained and filled at around 160k miles because the shop thought it was the transmission causing a vibration rather than the out-of-round CV axle
. The transmission was 100% fine but they recommended a d/f and I just went along with it thinking that it wouldn't hurt and it would be good to service it for the first time, ever. I'm not sure what fluid they used, I can't find the receipt now anyway. I'm fairly certain it was probably some universal fluid such as Maxlife, as they seem to have a penchant for aftermarket auto parts (such as the aftermarket defective CV axles they kept putting on).
I later had the transmission pan dropped and the filter replaced by another shop around 180k miles. Went in for some other services and since they would have the car for a few days, I'd figure I'd ask for another d/f and they asked me if I wanted a filter replacement. I thought why not, let's just do the filter too since I don't think it's ever been done. I didn't specify a fluid in the moment and according to the receipt I got they used Valvoline MaxLife.
Transmission is doing totally fine currently, absolutely 0 issues, despite what people have said about the dangers of servicing a high mileage transmission.
So right now the transmission probably has some mixture of WS and MaxLife and a relatively new filter. When would you do the next service, and what would you suggest? D/f, or pan drop and filter replacement, and what fluid should I use? WS or keep going with Maxlife.
