2014 Toyota Venza Transmission Filter; 121k miles
PA
The Toyota dealer did a transmission flush, dropped the pan, cleaned the magnets and installed the $45 direct import from Japan eBay transmission filter. The dealer did not even carry stock and the on-line price is a costly $95. Big bucks. Luckily it was zero $$ on the US customs duty. The technician reported very little debris on the magnets and the pics below support the ‘car care nut’ recommendation to change ur Toyota/Lexus ATF every 30-40k and then the filter never needs to be changed. Some history, the 14 Venza V6 AWD had ATF OC at 40k(WS),88k(RL D6) and now 121k(HPL green). I did aggressively swab the bottom of the louvres several times with a q-tip looking for any debris. Zero and amazing.
Any one interested in a 121k mi slightly used ATF filter?
An UOA will be done once I do my wife’s ES350 at the end of August and do an short mileage oc on the RX350.
After spending $7k replacing my transmission in my 2012 Sienna, I learned that even really well maintained with fluid and filter dumps you can't fix a weak spot in the case that allows a pressed in bearing to rotate and wear out the case sending fine metallic debris throughout the transmission. Hopefully you don't get the same problem.
I wouldn't install another car's used filter on my car. It makes no sense vs buying a new one with all the effort and ATF going in.
I was just being facetious and giving kudos to the Aisin engineers on their robust design. The transmission debris is so low that a filter with a 121k could be re-used and put into normal service.
It's almost like you don't need to replace it...
