My Jaguar doesn't even have a dipstick. The oil level is checked electronically. When I did my own oil & filter change I refilled it with exactly what the owners manual says is the capacity. The electronic reading, which is supposed to be taken with warm oil, 15 minutes after shutting down the engine read just below the maximum mark.
Then I let the dealer do an oil change. They over filled it causing a warning message on the readout. I told them to remove some oil.
I don't know how much they removed but probably too much. So I started adding 1/4 quart at a time and checking the readout.
Now when I check the oil I get the warning message that it is overfilled but it immediately turns off and I can see the level drop one graduation on the gauge and then another. So I am assuming that it is OK but why does the warning message come on for a second and then shut off ?
I sure wish it had a conventional dipstick. How much money would it have cost them to add one ?????
