Originally Posted By: severach
Originally Posted By: Vizzy
Doing a LOF is a simple job that anyone with an IQ of 60 could do in minutes flat and get it done right...
O rlly?
You mean LOF, tire check, pressure check, brake check, belt check, fluids check, grease fittings, talk to the customer, and write everything down...
in Michigan rust all in 30 minutes or less. Can't spend any more time than that upselling services, ya hear?
To do it in 45 minutes is poor quality. It can be done in 30 but the rush ensures that things will be forgotten. I'm never surprised when flat rate mechanics mess things up on a regular basis. Flat rate and customer satisfaction are diametrically opposed.
Ask how much time is allotted for a LOF. If it's 30 minutes or less for a single mechanic, steer clear. The lube shops can do it that fast because there are 2 or more working on the same car and some don't upsell things that would require lifting the car.
I can do a LOF and rotate in 30 min in my own garage with jack stands and a floor jack.
A person doing it on the lift with air tools should be able to do it in 20 min or less.
I mean, what do you really need to do?
Pull car in, check oil level.
Raise car, unbolt drain plug and take-off filter. While oil is draining, check all air pressures then take off tires and rotate.
Get flashlight and check for any oil leaks, wiggle ball joints with prybar.
Put on new filter, reinstall plug, refill with new oil.
