Mystic, Is your head spinning yet, because it sure sounds like it is, lol.
Your second paragraph really sums it up. It really doesn't matter what you use, so long as you are maintaining your gun. High quality gun care chemicals certainly help in the process.
To address a few other thoughts; Frog lube- I have tested this stuff out and while it is an interesting product, I dont care for it. To me, It is more of a waxy seasoning that you basically cook onto your guns similar to seasoning a cast iron pan. It really isnt an oil based lubricant at all and the process of seasoning your guns with it is just ridiculous if you ask me. The high price tag and the fact that it doesn't play well with traditional cleaners and oils adds to the silliness. Also, the fact that it was developed by a Navy seal really means nothing...... Just my 2 cents.
Lithium Grease- If you are going to use grease to lube a gun, straight white lithium grease is about the worst you could use. If you are going to use a grease, use a high temperature grease (preferably a synthetic) that does not dry out or get tacky when exposed to open air. Super lube is probably the best example of a grease that is good for guns.
Guns are not fragile little decorations that need the utmost in care or fancy chemicals. Feel free to experiment with them and find what you like for yourself. Recommendations from others are always great but your own experiences are the best to go by.
