Fascinating stuff, really! I love reading all the numbers and stuff. I would like to chime in with a few comments.
The pool guys analogy does not work with automobile oil pumps because the oil pump is a positive displacement pump. No matter what the restriction is downstream it will not affect the flow rate. The pool pump is a centrifugal pump whose flow varies with downstream restriction (head).
As far as the best filter. Although we call these filters full flow filters, they will be running in bypass mode sometimes (cold starts, high revs). Even if there is no bypass in the filter the engines bypass valve will come into play sometimes. So, in reality, these are all bypass filters! Thus, one could argue that smaller pore size is more important than flow. If you have nice small pores the filter will eventually filter out smaller particles. Which is a good thing.
As far as Shultz's comment that it does not matter which filter you use since most wear occurs due to 5-10u particles. Well, the reason that the most wear occurs due to 5-10u particles is because that is the limit of filtering capability of most filters. In reality the finer the filtering the better. If we filtered down to 5u we would find that most wear occurs due to particles of the 2-5u size.
I vote for the filter with the smallest pores. Having said that I might worry that the filter would become fully loaded quickly, but I do not think I will worry about that since most manufacturers dont even recommend changing the filter with each oil change. They must know that the filters do not tend to get fully loaded.
Go Fram Tough Gaurd! Go Pure One! Go AC UPF!
I wonder if Walmart will take back my two new FRAM XG's
Don't yell at me. I am just spouting off like everyone else.
[ April 14, 2005, 12:01 PM: Message edited by: Winston ]
