Me too!quote:
Originally posted by Ross:
Put me in the group that are concerned about the UPF flow rates. I would be interested in a follow up test. I can send you a upf-44 free if you want a donar filter.
Me too!quote:
No Grease's study take this into consideration.quote:
Originally posted by TC:
Due to a temporary quirk in my old computer, I couldn't open the file, but I assume (like the old Grease study) that it doesn't flow test filters, but rather, TESTS SWATCHES OF FILTER MEDIA in a stardardized area such as one square inch (???). If so, keep in mind that TOTAL MEDIA AREA WILL GREATLY IMPACT FILTER FLOW. So this should be considered with whatever application you're dealing with -- you can still potentially get "best filtration" and "good flow" in the same filter.
EXAMPLE: Rather than being "restrictive," with almost twice the media area, PureOne #PL24458 might flow like a fire hydrant compared to much of its Honda application competition:
PureOne #24458: est. 174 sq in
PureOne #14459: 116 sq in
STP #2903: 121 sq in
AC Delco #1127: 111 sq in
Mobil 1 #104: 99 sq in
Fram #3593A: 94 sq in
Bosch #3312: 81 sq in
Just some personal experience. Patman convinced to give the K&N filter (HP 1007) a try in place of my UPF 44 Delco filter. I spend a ton of time on a roadcourse and wanted lots of flow. I took some careful readings of my digital information on my Ls1 engine on a 2000 Corvette. At 210F the K&N always shows pressure at 40 to 41 PSI. The UPF 44 was always in the low 30s. This is in 6th gear on the highway at about 1700 RPM or 70 MPH which is what I based the readings on. Since then I have heard quite a few "track junkies" tell me the UP 44 is not the filter for the LS1 if you are concerned about flow rates.quote:
Originally posted by T-Keith:
The Mobil 1 filter does flow less than alot of filters, no lie there, just perception. I don't think anyone said it flowed poorly, only that it will flow less, because of good filteration. This is proven true.
I'm curious about the UPF filter as well. However I think that filter area doesn't make as big of a difference to flow as this study might indicate. AcDelco themselves claim that it flows better than the others. This test shows differently. It's definately a well constructed filter.
-T
I ordered a case of the Baldwins. It looked like my "sweet spot" of all the filters. Plus the physical construction looked like top notch from your photos.quote:
Originally posted by Grease is the word:
For mid-priced, I sure like the Baldwins.![]()
Olds,quote:
Originally posted by Oldswagon:
Excellent study! With each revision this study improves.
I do have one question though. The flow rates of filters with the 30W oil at 70*F, how exactly was this test performed? From what I gather, a small portion of the media was tested and then this data was mutlplied to reflect the total filter area? It is my understanding that you did not test the filters fully assembled on a filter mount?
In the report the test conditions were:quote:
The flow rates of filters with the 30W oil at 70*F, how exactly was this test performed? From what I gather, a small portion of the media was tested and then this data was multiplied to reflect the total filter area? It is my understanding that you did not test the filters fully assembled on a filter mount?
quote:
Originally posted by windcatcher:
My first post joined yesterday.Congrats on the ver 3 oil study excellant work.
I think there is some confusion here. The filter you mentioned does not have a bypass valve, since it is designed for a GM app. It does have a Anti-drain back valve, which is on the threaded end on ALL filters.quote:
My first post joined yesterday.Congrats on the ver 3 oil study excellant work. This year I have started using purolator oil filters only for my 2 cars and 1 truck, 97 cad 98 gmc and a 77 buick. I used to buy my filters on sale, most any kind ac,fram,quaker state etc. In 02 I had my first oil related engine problem going from nothern ca to pheonix az. a rod knock. I had 9000 mi. on the oil filter, fram/pennzoil mobil tri synthentic oil this was a improved mobil 1 over the original it wasnt out long and mobil came out with another improved version. My findings were little oil flow to the valves, oil only appeared at high rpm, Metal in the oil filter, changed the oil pump no help. I changed all the bearings (engine in car) still, very low oil flow but the knock was gone for a while. Cause Filter,9000mi,mobile 1? Now I use a gf3 oil citgo, purolator filter and I change the oil when the cad dic tells me too. In the Ver3 study I liked the numbers for the purolator but I was concered as to the location of the by pass valve. So I called purolator and talked to an engineer. told him I was using a premium plus L24011 (acP52-98 gmc) and a QS 3675a made by purolator for 97 cad. He said both filters have the by pass valve on the threaded end. Told me how to identify one, look down center if end is a smooth metal it hs the valve on the threaded end also put your finger in the threaded hole and feel for a raised area, that should be the combination by pass valve and anti drain back valve. Also the filter is made in the USA some purolators are made in india (low production types) It will be stamped on the box or the filter the country or origin.
The AC PF1218 (nor any of its clones) does not have a by-pass valve. It does, however, have an anti-drain back valve.quote:
I know the ac 35L does not have a by pass valve but I think the ac1218 does.
You can find the link the .XLS file here:quote:
