My battery/electrical toy obsession continues, I got me a new clore jump and carry air (JNCAIR). This is a really powerful jump starter with air compressor. It uses a 22 ah agm battery and has quite a few cool features.
*425 cranking amps 1700 peak amps (2 gauge cables)
*60 psi air compressor w/brass chuck and very accurate gauge (12 foot coil hose)
*manual analog voltmeter for internal battery status
*fully automatic internal AC charger with float mode (can be left plugged in indefinitely to AC power)
*12v accessory port for running accessories and DC charging of the jump starter (not automatically charged from DC)
*68 inch cables with industrial grade jaws
This thing is very professional grade and I am eager to have opportunities to test it's performance.
Pictures of my JNCAIR below.
They even included a 12v extension cable which you can use to manually charge the unit, but must be monitored during dc charge to prevent over charge.
The only thing you need to provide is an extension chord to charge the unit. I got a 15 footer off Amazon really cheap rated for way more than needed.
The unit is always hot and has no safety mechanism, so user caution is required to prevent arching
