If the battery is indeed the Ub12220 as I strongly suspect, it says right on the side 6.6 amps maximum, and I'd not exceed that unless I was observing the battery closely with a temperature gauge.
You could use a longer length of wiring from clore charger clamps set to 10 amps, to jumper pack clamps to introduce resistance, and introduce voltage drop, which will lower charge rate.
If you are really interested in this I recommend a clamp on Ammeter such as this:
http://www.amazon.com/Uni-T-UT204-Auto-R...amp+meter+uni+t
But if your only need desire for reading current is for battery charging, then get one of these:
http://www.amazon.com/GT-Power-Analyzer-...rds=gtpower+130
I'd not pass more than 25 amps through this continuously, and shop around, that link is just the first one which popped up. It will show Amps, volts, Watts, minimum voltage watt peak, amp peak amp hours, and watt hours.
With such a tool you can get a very good idea of how much the battery has accepted and infer how much it was depleted, and get a general idea of its healthy and capabilities.
If one is wanting to pass more than 25 amps through such a wattmeter this one has 8 gauge leads:
http://www.amazon.com/WindyNation-AccuMa...ords=DC+ammeter
I opened up my watt meters to solder 8awg to the circuit boards, replacing the aluminum 12awg leads and pass 40 amps continuously through it via 45 amp Anderson powerpole connectors.
These wattmeters however are not that great at reading currents under 0.5 amps. I had one, Andoer brand/clone, which did, but my other two do not, limiting their usefullness at low currents. Without a clamp on meter or using a DMM inline to verify, I would likely have remained unaware of this inaccuracy
