Deleted
They don't sell my size (14 EW).Buy yourself a new pair of sneakers while you're there.
Or Ace Hardware, seriously I had bought a pair of crocs and the dam pivot ripped out of the main body. Shoe Goo worked, and still is holding. Prepped with 90% alcohol.It didn't work well for me. It's not pliable enough. Best shoe and boot repair is Shoe Goo. You can get it at Walmart's shoe department.
I have a pair of Skechers as my back up pair but they need some fixin' up too.No Goodwill stores nearby that sell $5 or $10 shoes? Chin up m'boy, things will pick up soon.
If it was funny, PM me, I can take it.Deleted
No! Actually my wife recently bought some glue for her sneaker when we were in Walmart I posted then deleted because I can’t be 100% of the brand but it did mention for rubber soles ect.If it was funny, PM me, I can take it.
Barge SuperStik Cement is the proper urethane-based and waterproof adhesive that will remain flexible. Press together and/or pound for best adhesion. I glued myself to my workbench with this stuff. It's great.
The big bottle of GG reads to dampen the area 1st, apply the glue, then clamp it and wait 24 hours. What does dampening do for it?Probably similar to HH-66, also a urethane-based adhesive. But both of these fully are reacted urethanes dissolved in a solvent. Applying heat or a solvent to the bond will make it come apart and they don't bond well to some materials.
For a urethane adhesive that chemically cures, remains flexible, bonds better to some materials, and isn't affected by heat or solvents, use McNett's Seam Grip or Aquaseal. It's a PTMEG polyurethane prepolymer that's dissolved in toluene. (PTMEG prepolymers are solid at room temp unless dissolved in a solved). It moisture cures. The difference between Seam Grip and Aquaseal is that Aquaseal has more prepolymer and less solvent so it's thicker.
Another option if HH-66 (or likely the Barge product too) won't bond well is to add about 5% by weight of the original formula brown Gorilla Glue to it and mix it well. Don't add it to the whole can, just an amount you'll be able to use within half an hour. After that time the Gorilla Glue will have reacted and made it very thick. The resulting bond seems to be more resistant to heat and solvents, too. With such a small amount of Gorilla Glue it remains flexible and it won't foam up as it cures.
You yes. The mods? Maybe not.If it was funny, PM me, I can take it.
And I don't throw my old pairs out, at least not until they are really falling apart.I haven't bought a new pair of tennis shoes since 2015.
Does anyone know if there are screws or bolts made to fix a repair like mine?It cures by moisture, so dampening the surface helps it cure faster.
The original formula gorilla glue has the same instructions. I have never found it necessary to dampen the surface to make the original formula gorilla glue cure, but for some reason I'm always working with it in the summer when it's more humid...
...in the winter when it's dry dampening the surface might be required.
Also, I suppose, if you are bonding two non-porous surfaces, you'd want to dampen them.
The soles are rubber - no? I don't think you can weld rubber like you can plastic?Does anyone know if there are screws or bolts made to fix a repair like mine?
I have actually welded PVC and fused it together. I bet I can weld my shoes that way...........
Now Pyrex, that's a totally different animal!
Yeah, I'm just kidding.The soles are rubber - no? I don't think you can weld rubber like you can plastic?
I think screws would be a bad idea on a tennis shoe.
The ones I have had the soul come apart was too little glue from the factory. If the factory uses glue I assume that's the most efficient method?
Only on this website can you come along and say "my shoe broke so I fixed it with some industrial Polyurethane rubber I just happened to have around", and everyone finds this normalI used Polytek Poly 75-80 polyurethane molding rubber
