2002 Silverado 5.3L RWD Vibration
CA
Recently replaced worn steering and suspension components on our truck with 480k plus miles. I was hoping that by replacing many of these worn suspension components, all of the irks and quirks (VIBRATIONS) would go away. The rack and pinion was shot, the front upper and lower control arm bushings and ball joints were shot, the front wheel bearings were lose, the center carrier bearing was worn, drive shaft u-joints were worn, left rear axle and bearings worn, differential overhaul conducted at a shop (carrier bearings replaced, backlash set, pinion preload set). The differential/driveshaft repair shop also stated that the driveshaft had no balancing issues. They checked it.
I had replaced the pinion seal and crush sleeve (washer) myself a few years back but did not use the correct procedure/method to set the correct preload on the nut, instead, I took a short cut and installed the pinion nut back on by using the "thread count method" (incorrect). This would come to bite me later. Replacing a leaky pinion seal has its proper steps (procedure) when tightening the pinion nut back on. Sole reason for premature wear on my differential and reason for the differential fluid leaks.
All this work and I STILL HAVE VIBRATION upon acceleration from a stop, and VIBRATION when driving around town (when accelerating) and driving at freeway speeds. When the truck is moving on a road or freeway, accelerating or not, as the trucks suspension travels up and down, there is road noise and vibrations that are very pronounced and felt at our feet but not felt at the steering wheel.
Took the truck to a transmission shop yesterday and the shop owner ruled out a failing torque converter. The shop owner asked if I had checked the drive shaft and I told him that the drive shaft was checked at another shop. He also asked if the truck was lowered and I told him no but did tell him that my front springs were original (all shocks replaced) and rear leaf springs were original. He was thinking that if the truck was lowered that the angle on the driveshaft might be causing the road feel vibrations that he experienced and I was complaining about.
Going to take it back to the differential/driveshaft shop today to have them look at the driveshaft again (slip yoke, etc).
Any advice is greatly appreciated.
Is this vibration goes away if get off the gas meaning you going 40 mph and you take your foot totally off gas. have vibration upon acceleration (motor /trans mounts) ? Are you feeling it in your steering wheel or in the seat of you ass.
You can check u-joint angles easily enough, but if everything is truly stock it shouldn't matter. Even sagging springs shouldn't cause enough change to matter.
Is this a 2-pc rear d/s? Are the u-joints phased properly? I'm assuming it's a slip shaft at the trans and there's no way to get it out of phase, but I'm not certain.
If you have done all that I would try brand new wheels and tires and probably look for a set of factory brand new take-offs if you can find some that fit. It sounds like you are throwing a lot of parts at it.
The vibration/shudder is more pronounced when accelerating at a stop and while driving and accelerating. If the pedal position stays at a certain position (speed) lets say 60mph, and you dont move from that speed, there is no vibration until you depress the pedal to increase speed.
Also, if there are dips, not bumps, on the freeway, such as driving over bridges (freeway over passes), you can feel the vibration/shudder at your feet, while the truck travels up and down. Nothing at the steering wheel. You can hear the road noise on the road and almost makes it appear that its the tires.
Again, at a constant speed while driving on the freeway, it feels normal. If you drive thru a dip, as the trucks suspension travels up and down, you can hear the road and feel the road and makes you believe that the tires are the issue. If taking off from a stop, you will feel something is not quite right with the transfer of power from the transmission to the drive shaft. Like a shudder feel.
Motor mounts and transmission mounts are brand new and Genuine.
How much vibration are we talking? Enough to feel a slight buzz in the wheel, seat, or does the vehicle shake like a bad balance?
Have you checked the tires for a seperation?
What really comes to mind is, have you replaced the motor mounts?
I had a bad LH mount which gave a visible rise to the engine under load/powerbrake. This cured the thunk, but I still had what felt like a rough idle and grittiness under load. The RH mount was so compressed it was almost like a solid mount. Once I replaced the RH mount it was like a switch....smooth idle and acceleration.
