OVERKILL
$100 Site Donor 2021
....That is not the feature we are discussing in this thread, which limits power output once oil temperatures get too high...
I am well aware of that. Still looking for proof of the oil temp based limp mode on the Mustang engines....
Originally Posted By: CATERHAM
So based on the Ford engineers comments, their is also a fail-safe system to deal with high oil temp's.
What Ford Engineer's comment?
What Ed posted earlier:
Quote:
Consideration was given to an external oil cooler, but ultimately it was decided not to penalize all Coyote buyers for the occasional antics of a miniscule fraction of owners. Oil temperature rises precipitously when the Coyote is revved more than 4,500 rpm for extended periods, and then an external oil-to-air cooler is vital. But those conditions can only be reached on a road-racing track, so the expensive cooler was ditched and engine management strategies were used to protect the engine during hot idles. However, the mounting area for the cooler was "protected" during the 2011 Mustang's development. That makes it easier for the open-trackers among us to fit a cooler (highly recommended by Coyote engine designers), and tells you something about Ford's intentions for special editions of the Coyote-powered Mustangs.
And don't worry about the occasional open-track without an oil cooler. The engineers say the oil cools quickly as soon as you take your foot out of it, and the engine management will limit the torque output if the oil gets too hot.
Forgive me if I don't rely on second hand heresay from an anonymous writer. Still looking for proof...
Really thought it would be in the owner's manual, but alas, (unless I just missed it) it's not. But the coolant limp mode is clearly listed in the same owner's manual.
The search continues....
Not really anonymous, the rag it came from is pretty well respected in the Mustang community. But if you want it first hand from Ford, as I said earlier, I can't help you out there, sorry.
