Originally Posted By: Carzzz
Originally Posted By: asiancivicmaniac
Did you actually speak to someone from Nissan Canada or just your dealer?
I don't know about Canada, but you can use whatever parts here as long as they meet oem spec.
My parents have a 2005 Nissan Quest. No oil consumption issue, but always makes a high pitch noise (tried GTX, Forumla shell, QS, PP, etc) and i guess the noise is coming from the timing-chain. Numerous nissan dealers deny there is a problem. i am expecting the timing-chain is going to fail anytime although it is under 45k km/ 30k miles.
i called the 1-800 number and inquired about warranty on powertrain. They said if the filter causes the engine to fail, it is not covered for warranty. Nissan does not recommend other oil filters that are not designed by nissan. So basically, the rep was saying if your engine fails, nissan is not going to honor your warranty because you put in a different filter. Similarly, look at the GTR, if you turn off the VDC and your warranty is voided. NO more nissan!
We have a 1996 with that high-pitched whine, but the 1st gen vans were known for transmission whine.
And it used the old style PH3682/15208-55Y00 filter. I used Fram, Wix, ST, Mahle, STP and Beck-Arnley with no issues.
