Originally Posted By: ekpolk
Originally Posted By: fsskier
The 3.9 Chrysler seems to run forever using the recommended 5W30 I have know of two used in commercial towing duties that went well past 200K miles and still ran like new. As a 90 degree V6 it would be an odd firing motor, Chrysler chose to split the crankshaft throws only 15 degrees, stating that a 30 degree split would not be strong enough for towing service. Note that the 3.8 GM motor - with a 30 degree split) was always kept out of pickups (except for the Typhoon?) and never recommended for towing.
I bet Buick GN can tell us lots more here!
Well, I'd better chime in too. The 231/3.8/3800 is one of the most reliable, solid engines that's ever applied torque to a transmission. Although it was originally an odd-fire engine, early in its life (late 60s, early 70s, I forget exactly when) GM went with a split crank pin which made the engine even-fire, despite its 90 deg bank angle.
I've owned a couple examples of this engine, in supercharged form, no less. I don't think from my study of the design that it was so much a matter of it being kept out of the trucks because it wasn't up to the task, GM simply had engines that were better suited to the task. Don't forget that this was an engine that originally went into production in 1961 (coincidentally, the year I appeared in this existence...), and had roots in GM's experimental aluminum V-8 from the 50s (hence the 90 deg bank angle). During this time, GMC had a series of MONSTER truck V-6 engines (perhaps not by then shared with other divisions) that obviated any need to pull the 231 from the cars. IIRC, the GMC V-6 topped out at over 7L of displacement (that must have been a smoothie...). IMO, no need to have used the 231 in the trucks -- plenty of other engines meant for the task from the outset.
p.s. Someone correct me if I'm wrong, but IIRC, the venerable 231/3.8/3800 actually started production as a 198 cid engine (roughly a 3.2 or 3.3 depending upon rounding).
It was something like that. It's based on the old 215" aluminum V8 and was eventually increased to a 3.8L. I can't remember just how small the orignal Buick V6 was. The 3.0L destroked V6 was installed in many FWD cars of the late 80s.
