GM's 230 mpg Chevy Volt aka Toyota Prius killer
Leave it to GM to over-promise!
How about a "mpg" measurement of hybrids averaged over a full tank of gas, starting with "dead" (20%) batteries. That would normalize the figure.
Originally Posted By: oilyriser
How heavy is a gallon of electrons?
there is a mass and volume associated with an electron. The question becomes what packing factor/geometry are we assuming? I assume that you are assuming an electron to be spherical.
230mpg + ton of coal
Cool, I guess charging it at the local coal electric plant doesn't cost anything financially or environmentally?????
I great way to get rid of nuclear waste is to mix it into the paint of all these electric vehicles.
Narrow minds and farsightedness rules :-)
Oh, I almost forgot. We're putting all the coal plants out of business by only building new natural-gas power plants. I guess that natural gas will never run out and is in unlimited supply..........
The NGers putting coal plants out of business is a classic lack of central planning for infrastructure.
The "market" doesn't always work.
Coal baseload requires heaps of time and capital to build, and has to be designed over "average" requirements, to meat the majority of the peak.
Most of the profit for a coal plant occurs during the peaks.
Throw in a (relatively) cheap Simple cycle GT Natural Gas plant, albeit with high fuel costs, and they get to own the peaks. The coal plant profitability tanks, and investors won't run them (or maintain them), when the see the cram that they can skim with simple cycle GTs.
The simple cycle GTs will never ever supply the baseload, and they'll certainly never ever be supplying the electric vehicles, and certainly not at 5c/kWhr.
(and they'll never be powering the "hydrogen economy" boondogle either).
We're more short sighted WRT future energy production than ever before...
You bring up some good points. The Volt will be of little use to those driving 50 miles each way to work, or on the go all day. However, for many, it will shift our energy usage away from foreign oil towards whatever we use to generate electricity. One interesting idea I have chiefly read about in Forbes magazine, is using the battery pack in all the electric cars to meet peak loads, with compensation to the owners. The biggest drawback to that I see is a lack of time to recharge the cars between the early afternoon peak, and the late afternoon commute. Another concern is back feeding to a power line under repair.
Too bad neither presidential candidate had the guts to say ''America needs nuclear more than I need Nevada's 3 electoral votes. It will be the foundation of my energy policy including Yucca Mountain.''
+1 on hydrogen. OK, all we need is a source, and a good way to store it. Other than those minor details, it is a great fuel. Are 2 major breakthroughs too much to ask?
Note, markets are at their worst when distorted by the heavy hand of the government. See recent financial results. Also note the results of regulating automobile millage and safety more strictly than that of trucks.
Originally Posted By: XS650
Originally Posted By: Bamaro
KrisZ said:
Quote:
Do you really believe Volt will drive 230 miles continuously on one gallon of gas? Because that's what GM wants everybody to think by posting this stupid number.
Its not a 'stupid number'. It is based on an estimate of how the 'average' Volt owner will use the vehicle. If you drive 20 miles round trip each day you will get infinite mpg. If you push it to its practical limit each day you will get much, much less than 230 mpg. The 'average' user will be in between, aka 230.
It's stupid number because you can change it to anything between a much smaller number to infinity just by tweaking the way it's calculated. It doesn't mean diddly
You seemed to miss the part about the 'average volt owner' How would you suggest they measure it?
I would call the characterization "problematic," perhaps not worthless altogether. The vast majority of people who bother to measure mpgs are accustomed to doing the simple math on miles driven over gallons used in a conventional car. No problem there.
Now for the true total short trippers, there will be NO mpg calculation at all (yes, this is an extreme, I know). If you always plug your Volt in at home, and never use up the at-home charge, in theory, the Volt's gas engine will just rust away, and your "mpgs" will be mathematically meaningless, as it would require you to divide by zero.
Things will be more difficult for the mixed pattern drivers, as they will need to (if they want meaningful data) to account for electric-only vs mixed power driving.
For the long-trippers, time will tell whether this mode of hybridization (serial, as implemented) is more or less efficient than the parallel hybridization, as implemented in comparable cars from other makers.
Originally Posted By: labman
Too bad neither presidential candidate had the guts to say ''America needs nuclear more than I need Nevada's 3 electoral votes. It will be the foundation of my energy policy including Yucca Mountain.''. . .
Ignoring the superficial political aspect, well put!
They should measure it starting with the fuel burned by the average power plant to produce the energy consumed by the car and add that to the gasoline consumed by the car.
You charge the EV using a natural gas fired generator in your basement that makes hot water with the waste heat. A 20 mile hwy commute in a Camry sized car takes about 0.625 gallons of gas, which makes about 12700 BTU of mechanical energy to move the car. An electric car will need about 16,000 BTU of electric energy to charge its batteries for a similar trip. An efficient co-gen system will make about 2x as much heat as electricity, or 32,000 BTU, which is enough to heat 42 gallons of water by 90 degrees F.
There's an Oz company making a 2kW NG fired fuel cell that doubles as a water heater...87% total efficiency
that's cool
The reason I said the number is "stupid" is because GM came up with a "duty cycle" to get this number, and it's totally meaningless to an average person. Like I said before, an average person will think that you can do 230 miles on 1 gallon. Isn't this what everybody expects when looking at a regular car. If i see 25mpg city, I know I will get this mileage (or close to it) when driving in city, no matter if my commute is 40 miles or 20 miles, as long as it is in urban setting, there are no special duty cycles or circumstances involved.
GM drove the car on a full charge for 40 miles (or whatever they could squezze out of the battery) and then a few more miles on ICE, then took total miles (battery only + ICE) and devided only per fuel consumed. But of course this is not mentioned with the number.
GM should have two numbers, one is the cost of running on battery power only (people with 40 mile or less commute) and then MPG when ICE kicks in. Because this is the series hybrid, once the battery is depleted, ICE will run continuously to power the electric motor not to recharge the battery (this is what GM claims) so there is no way to get 230MPG in this scenerio.
If you read TTAC, they actually predicted this situation, knowing that GM wanted a shocking number, and GM is actually lobbying EPA to accept GM's duty cycle as a meaningful MPG measurnment method.
There's a (somewhat) easier way of comparing what it supposed to be a car to protect the environment.
CO2 per passenger mile (or tonne mile for trucks).
Ultimately, what 95% of hybrid buyers care about is cost of ownership. The greeness factor is overrated; buyers didn't give a [censored] about the greeness of hybrids when gas was $1.75/gallon.
The cost per mile should be posted on the car, and they should assume real world energy costs. $0.13/kwh and $3/gal. Then let buyers decide whether the Volt's $17k premium is worth it.
That assumes CO2 is causing damage to the environment. Not a proven fact.
Please point me to where I said that it was.
If the push to these cars is for reduced CO2, then that's how they should be measured, in lieu of any valid means of comparing "fuel consumption".
You may be partly right. The hybrid owner I know best is may daughter. Shortly after graduating in 2001 with a degree in environmental engineering, They bought an Insight for her 60 mile each way commute. Within a few years, they traded it on a Civic Hybrid and she had found a job much closer to where they were living. They are no tree huggers, but are environmentally aware. They are also engineers. Perhaps more image conscious than I am, but not affluent enough to waste thousands on a car to support it.
I could see them buying a Volt. The Honda will be aging by the time it is available. I don't know how fast battery recharging stations as an employee perk will spread. With her working for the city, and him a university that is the biggest employer in town, I could see it happening early there. Parking lots where you swipe your card and plug in? Or pay a dollar extra for spots with an outlet? Even with all their charging at home, it would work well for them. Much of their driving is less than 40 mile trips.
While GM may talk CO2, much of it is dollars and foreign oil. Coal may be dirty, and CO2 emission rich, but it is American. I is amazing how many people talk buy American, but drive guzzlers.
While I fundamentally agree, once the crude is delivered over here, there are LOTS of decent chemical industry jobs that are supported by the processing for fuels, other products, etc.
