- Joined
- Dec 16, 2022
- Messages
- 690
Except they don't differ...
Not a good place "for a start".
Somehow you got upset in this thread and are now just being difficult. That's fine, I'll move on.
TurbochargedBring back the slant 6
Spreads the wear out when alternating the cylinder cut outThe 2.7 does not alternate, neither does the old GM AFM system or the Ram MDS. The new GM DFM does turn off between 1 to 7 cylinders and it does so as needed, it's constantly adjusting which cylinders are running. It's all seemless to the driver for the most though they have pretty bad failures in this system right now.
Shhh my 95 GMC doesn`t know that.They used to say on a quiet night you could hear Chev trucks rust.
What about your 77 with the BBC?Shhh my 95 GMC doesn`t know that.
Two small spots at 10 years of age, none since. The 2016 Equinox has two spots that are just surface rust at this time. Will decide soon whether repair or trade. Wife will decide this one. Rustiest car we ever had was a Nissan, couldn`t keep ahead of it.What about your 77 with the BBC?
ask if anyone with the EB2.7 has gotten over 50K without the bottom end being replaced - its not a deal breaker problem as in the feds have to get involved and ford is replacing every one under warranty with no hassle, but this NEVER happened in the old days.I’d like to know if there are any high mileage GM 2.7 stories. Same with fords ecoboost 2.7.
I haven't heard of any "bottom ends" needing replaced on the 2.7 eco boost. There are plenty of examples of these motors with high miles out there. Hopefully, knock on wood, mine will be one of them. I'm only at 78,000 now with no issues.ask if anyone with the EB2.7 has gotten over 50K without the bottom end being replaced - its not a deal breaker problem as in the feds have to get involved and ford is replacing every one under warranty with no hassle, but this NEVER happened in the old days.
You also can't compare the 2.7 from GM vs Ford directly like that. They're completely different trucks, and the Ford weighs less for a start as its basically an aluminum tin can.
I'll inform the GM engineering team.Chevy came full circle...took em 100 years (a 4 cyl in a fullsize pickup)
If the truck is used as a tall car, it might give good service. but if its used to work, only 4 cyls means the thrust side loading is twice that of a V8 and its only a matter of a few miles before the bores oval and the rings stick. And we aint even talking piston speed. Engine 101. 50 year old C10s will outlast these (assuming the new stuff does not melt away since GM abandoned all pretense of corrosion protection - the new sexy is gaping holes in the body while you are still making payments) #NOTAFAN
oh they know this all too well. in fact, it was THEIR edict of 1L per 1000lbs curb weight which they so gleefully violate. but a long as people are going to shell out bux for something that will have rust before its paid off - can you blame them?I'll inform the GM engineering team.
well you are not going to hear about it if you are not looking for it right? I happen to have one of these trucks in the extended family and it was brought to me first before I said they had a warranty claim. I believe I mentioned that ford IS covering it and replacing the motors with little drama so point for them, but I also mentioned this was unheard of in the past. (when the base motor was the 300-6 can anyone anywhere name any failures?)I haven't heard of any "bottom ends" needing replaced on the 2.7 eco boost. There are plenty of examples of these motors with high miles out there. Hopefully, knock on wood, mine will be one of them. I'm only at 78,000 now with no issues.
Where is this edict from? Ive not heard of this before.oh they know this all too well. in fact, it was THEIR edict of 1L per 1000lbs curb weight which they so gleefully violate. but a long as people are going to shell out bux for something that will have rust before its paid off - can you blame them?
oh you would have to search the archives...Im thinking jest prior to obama era when GM defended its continued use of large displacement (mostly pushrod) engines.Where is this edict from? Ive not heard of this before.
Sometimes i do read, yes. But you are referencing something from over 12 years ago? When it comes to sales and marketing, the only thing cast in stone is “always be closing”. How many of the bigwigs from back then are still with GM, backing up and enforcing such an edict?oh you would have to search the archives...Im thinking jest prior to obama era when GM defended its continued use of large displacement (mostly pushrod) engines.
Dont you guys actually follow any automotive related news?
I think the bigger point is that the engineers - professional grade I think they call themselves - recognized that to do big things you need big motors. It has more to do with mattalurgy and pistons speeds and the aforementioned side loading and wear etc etc than physical size - for example fords 4.6L v6 (and its followons) are in a larger package than the old 385 motor or the navistar...we are talking swept area or displacement.Sometimes i do read, yes. But you are referencing something from over 12 years ago? When it comes to sales and marketing, the only thing cast in stone is “always be closing”. How many of the bigwigs from back then are still with GM, backing up and enforcing such an edict?
