Originally Posted By: ZeeOSix
Follow along. I'm not talking about the test you did on your car, I'm talking about your thoughts on the additional temperature rise due to high HP levels for extended periods further increasing the sump temperature. You came up with "40 C" for some reason.
Originally Posted By: Shannow
Can't test on that car as no towbar, but the temperature increase due to load isn't going to be 40C.
I never said it would be 40C more ... I said it would be a significant rise, which is more than just a few more degrees C. You come across thinking the temperature rise won't be much more due to the engine putting out 30 HP vs 300 HP at X RPM. Guess it goes along with thinking a PD oil pump doesn't force any additional oil flow through the bearings either.
OK, again, you are describing "my thoughts"...have I ever said (or though, as that's your forte in answering unthought thoughts apparently) that it's "only a couple of degrees" ?
(Hint, no).
I have said that RPM is the dominant factor in oil temperature rise, and have never discounted load as a part factor...it's just not the MAJOR factor.
As to your incredulity, the point at which the type K is situated when I drop it down the dipstick hole is exactly where the full/add zone on my dipstick is...it's right where the oil drains back from the rotating assembly, and prior to it making contact with the sump walls...so it's an accurate reflection of what's going on with the oil exiting the spinny stuff.
HTHS...it's 150C, as that's reflective of bearing temperatures...why the incredulity ?
