Hi all,
A while back, I bought a 2008 Corvette Z06. The car has an 7.2L LSX engine (iron block, instead of the original 7.0 aluminium LS7) and makes close to 600 hp (unsure if that is at the wheels or the engine, but I suspect at the engine). This is a dry sump (original GM system) engine as well.
From the previous owner, I received some Valvoline VR1 5W50 that is -assumingly- currently in the engine. I did some research in the past, and this oil seems a bit too thick and I am questioning if it is the right choice for my driving.
In my mind, I will take the car to trackdays and it will be used and abused, but realistically, it's just a street car that doesn't even get used all that hard (it's too fast to drive anywhere near the limit on the street). On ls1tech, a seemingly very knowledgeable guy recommended 0w40 or 5w40 that meets ACEA A3/B4 or Porsche A40. GM's recommended oil (for the original engine) is 5w30, the oil standard they retroactively recommend is apparently "dexol2".
I am in central Europe, temperature varies from -15 to +35. The car doesn't get driven much, but I did buy a set of uhp winter tyres for it, so it might get used in that range of temperatures. I'll probably end up doing between 5000 and 10 000 km, leaning more to the 5k. Of those km's, a lot will be boring highway on cruise control at 130 kph.
Looking on oeldepot24.de (bought oil there in the past, prices seem good, but otherwise no affiliation/preference), one of the cheaper options that seems to hit the marks (acea a3/b4, Porsche a40) is "Rheinol Primus 5w40": https://oeldepot24.de/Swd-Rheinol-Primus-HDC-5W-40-5-Liter
Another cheap oil, but of a well known brand, is this Mobil 1 ESP 0w40. It gets the Porsche a40 standard, but is a acea c2/c3 oil: https://oeldepot24.de/Mobil-1-ESP-x4-0W-40-1-Liter
Next up are TotalEnergies Quarts 9000 (or 9000 Energy) 5w40
Further up are multiple variants of Meguin: high condition 5w40: https://oeldepot24.de/Meguin-3198-megol-Motorenoel-High-Condition-5W-40-5-Liter
New generation 5w30: https://oeldepot24.de/Meguin-6513-megol-Motorenoel-New-Generation-SAE-5W-30-5-Liter
Efficiency 5w30
And last but not least Low Emmision 5w40: https://oeldepot24.de/Meguin-6574-megol-Motorenoel-Low-Emission-SAE-5W-40-5-Liter
(that seems to be hitting all the mentioned standards).
And that's just scraping the top of the ice berg. So in short => I have no idea what to buy, or what to look for.
I am not necessarily trying to go low budget, but I don't like spending more than needed/without tangible benefit. Oil on forums often seems to be more religion than reason, so I am hoping to find a more down to earth answer here.
Efficiency 5w30
