10W-40 didn't cause the early problems in gasoline engines that were seen in diesels. They worked just as well (poorly) in all gasoline engines, including GMs. There are plenty of people here who have seen the lives of engines of all makes cut short due to the 10W-40 oils of the '70s and '80s. The group I base stocks and shear prone viscosity index improvers made an oil that was only suitable for very light duty service with short oil change intervals. The problem was the viscosity spread. It took a large amount of viscosity index improver to create a 10W-40 and under heat these broke down and formed deposits. It happened in both gas and diesel engines. The process was accelerated in diesels due to their higher piston temperatures.
Yes, 10W-40s are better now. The advent of group II and II+ base oils and new, shear and heat stable viscosity index improvers have made 10W-40 viable in gasoline engines. They are still not the proper oil for most diesels. In a non synthetic, 15W-40 HDEOs are the oils of choice for diesel applications and are a better choice than 10W-40 in many gasoline applications. I run Chevron Delo 15W-40 in my GMC 5.7 gasoline engine. Todays oils are much better, but an oil with a narrower viscosity spread is still the better oil. I still won't use a 10W-40 or 5W-30 non synthetic oil in any of my vehicles. I stick with 10W-30 or 15W-40 if not running a synthetic.
GM had just entered the market with diesel engines in light duty trucks and cars. Should GM have recommended 10w-40 in a diesel in the first place? No. Did they do enough field testing to find that out? Obviously not. I am going to give them the benefit of the doubt by saying they banned 10w-40 in all their engines based on the poor performance they saw in the diesels. They could recommend 10W-40 for their gasoline engines now, but CAFE is an issue at this time, so they won't. CAFE was not the reason for the initial prohibition on 10W-40, it was for sound technical reasons.
Ed
Ed
