Originally Posted By: ArrestMeRedZ
Fast, I don't think you are going to get a lot of support here for someone who won't check their oil levels, especially after driving that many miles. The amount of usage you described is pretty much normal. In fact, it's pretty good. If you take it to a dealer with this complaint, I guarantee they will do something. They will laugh at you.
You know what they call those millions of people who won't check their oil level? Pedestrians.
My sister drives over 60k miles a year. She also won't check her own oil. But she will go to a full service gas station and have it checked at regular intervals.
There are WAY TOO many responses for me to quote & answer them all. I am getting hammered here with a FEW people who do see my point without attacking. I am actually with you guys for the most part (even the attackers), but on my G/F previous car, she had been doing the 3k quick lube place (before we got together) and had never needed to check the oil between changes.
Sometime after we got together, I increased her interval on her old Camry to 4k and then sometimes 5k all on conventional. But she has never had a car that would go 9k before the factory OLM system told her it needed to be changed. I am frustrated because explaining this to someone who is not car savoy (unlike all of us), is hard because she got a new car and wants to drive it and change the oil when needed; just like her old car. But the difference is that the old car was going 3k on conventional most of its life, and this car wants to tell her to go 9k-ish and that introduces extra work in her haing to check the oil (or myself) and in her mind I think she wants to just drive it and change it like she did with her old car. Understandibly, an owner should know how to check oil and she does, but would rather drive as far as she can without having to add oil unless she was in a POS '79 chevy pickup that burned oil due to a mechanical problem.
This car is 1yr old, and runs & drives perfect; in fact it is a joy to drive. I doubt that there is something wrong with the motor; rather going 7k on Mobil 5000 conventional is most likely the cause of it being low on oil because GM's OLM seems to think the car can go that long on conventional.
MANY members here say that 5k is about the max they would go on conventional and so does Mobil 5000 oil.
I now suspect that the reason that the OLM can go so long on conventional is because over the course of 9k, you practically add 50% new oil in the crank case LOL.
But again, I am one who DOES check his own oil regularly but I like to find intervals where I change the oil before I have to add any (usually between 3-5k) on my vehicles.
I do appreciate the input guys; despite the controversy; hopefully some of you that take the time to re-read the post will understand where I coming from. I CHECK MY OIL & HERS. But nobdy should be going 9k on conventional if it is enough time to burn off a significant amount of oil. I read me manual but most people don't...you all know that.
NOW HAVING SAID ALL THAT...I think Jeep has it right. My dad has an '08 SRT-8 and I copied this page from his manual today and it says 6k TOPS. His takes Mobil 1 0w40 and I am kinda upset that the dealer forces him to change it every 3k and he believes them over me, but aside from that, I wanted to illustrate what I wish her manual said. instead of a 9k OLM, if it just said every 6k, then I would have her run it and it would use maybe just under a QT of oil per OCI and we wold not be having this post.
I will probably solve this issue by changing it at 50% with conventional from now on. OR AT LEAST topping it off on cue at 50% like one post above said he did for his father's Colorado. But if I decide to go the 50% top-off route, I will most likely use PP instead of conventional. But just think of all the poor cars that will be traded in and have been run low on oil due to lack of owner knowledge or responsibility to check the oil on a regular basis duw to the insane GM conventional OLM recommendations.
