My wife has a 2009 Chevrolet Traverse. It is a great car for a family. Plenty of room and power, plus she doesn't want a minivan.
I was going to leave the factory fill in the engine until about 7K or until the GM OLM told me to change it. I get updates every month with the OnStar package that projects when the OLM will say to change the oil. I got an e-mail from OnStar that reminded me that the oil had been in the Traverse for over 9k miles!!!! The OLM was projecting 13k miles on dino. That just seems like too much.
I filled it full of 5.5 qts of Castrol Edge and used a M1-113 filer. I am going to change it at 10k or sooner if the OLM tells me to change it. The dino in the engine was very dark when I drained it.
I would like to get a used oil analysis on the Edge. Would it be best to get a used oil analysis at the end of this run of 10k? Maybe do a 5K run and then test? I have a Fumoto valve that I took off my Tahoe that I am going to install on the Traverse. The Fumoto Valve makes changing oil a piece of cake. The oil filter on the Traverse can be reached from the top, so I bet I could change the oil and never have to put both knees on the ground.
The GM OLM and the extended drain oils (MIEP and Edge) seem to fit together nicely. It might take 6-7 months to get the 10k miles, but I will keep you posted.
