Been changing the 2010 Traverse every 5k miles, first with Mobil 1 and now Valvoline Synpower. I bought it used at 99,000. According to the Carfax I got with it, it's already had the ECU update to correct the OLM for which there was a TSB. So far, it hasn't had the dreaded timing chain issues. Now almost 5k into this oil change (nearly 125,000 on the odometer), and oil life is at 54%. So, if my commute is mostly highway, and I occasionally tow a 2000 pound camper, would sticking with the OLM be OK? A quick search turned up a used oil analysis with conventional that didn't look bad. I've just heard that the 3.6 is hard on oil, and has a reputation for worn timing chains.
