GM now saying to use 0w40 in 21-24 6.2L
My 2025 Camry calls for 0W-8 in the manual and on the cap. It gets 0W-30. Got 78 mpg yesterday on a 10 mile trip with stops and starts, doing the speed limit. 68 percent EV mode I think it read after the trip. Mostly I get about 65 mpg on that route. Averaging 57mpg from a mix of city and highway driving. I doubt my mileage would be any better with 0-8. Long story longer, I hop for the GM customers the 0-40 does the trick. That's a lot of money to spend and have your engine blow up.
Outside of the US the newest toyota engines which spec 0w-8 can go up to 10w-30. I wonder if Toyota will at least give the same broad oil selection the rest of the world gets now that the new sheriff is in town.
It's NOT "thicker oil is better". It's the crank clearances are too big, completely out of spec. and the heavier oil takes up the slop.
It's very simple math. Heavier oil takes up .001 of bearing slop. It's a solution to the problem.
Thicker oil: takes up the slop if there's slop, and when the clearances and specs are correct, separates parts better for less wear?
Thanks. I figured as much. It's not a solution at all. There is a mechanical/manufacturing flaw.
Also, engines can run on multiple viscosity grades as most have said for years.
How many other vehicles from all automakers out there are out of spec, and to what degree are they out of spec? Nobody knows. But likely there's variances, so if thicker oil is used from the start, then could it not provide a buffer for those variances? And could it not also protect all engines better, for longer, regardless of the spec?
I don't know, maybe you're right. I'm skeptical the viscosity increase will make a difference.
Yes they are attempting to mitigate a material or design defect with increased HT/HS. So it is using a thicker oil as “better”. Increased film thickness is the objective.
Of course they aren’t the first to try this. Maybe it will help somewhat for some period of time until they get a permanent solution worked out. But it’s still a bandaid on a problem for now.
Oil pump isn't calibrated for xW-40 either.
Low oil pressure from the variable pressure oil pump is likely the cause of the engine failures especially if it begins at the valve train.
Hydraulic actuated switches and solenoids require high oil pressure to operate properly.
Is there a way to defeat the variable pressure oil pump?
Can it simply be unplugged?
Even if it worked, wouldn't that throw a CEL, and then not pass inspection in many localities?
It will. On my Tiguan I had the variable pressure solenoid fail (high) and it eventually gives a CEL after multiple drive cycles. If it fails low then it gives a flashing CEL with a warning about engine RPM. There are only two levels, low and high.
But I'm sure that as part of a fix or recall the ECU could be reprogrammed to only operate the pump at high pressure and they could suppress the CEL.
If you live in a warm climate use 15W-40 , in a cold climate use 5W-40, why just optioning 0W-40?
Oh yeah 0W for gas mileage. :ROFLMAO:
They finally figured out sewing machine oil viscosity doesn't help their products last past warranty.:ROFLMAO:
The same oil pump has been used since the 2014 model year on all Gen V engines. The lifter issues are not caused by low oil pressure or have these engine had low pressure issues.
I was thinking 0-40 so people would have to go to the dealer for an oil change, or to buy their expensive 0-40 dealer oil that you can't find anywhere else.
