"In the L87 engines GM will be replacing your 0w20 oil with 0w40."
hello dolly
I may be a machining debris in the crank passages leftover after rinsing/flushing as far as anyone can tell.
I don't recall the L86 having a TSB. That specs 0w-20. Many of them out there working with high miles.
I see no reason not to beyond price. Is is expensive around $10 per quart. Formula wise it is alleged to be the same as the old Mobil 1 ESP 0W-40 that was always touted for the Corvette.The question is: do you use this Super Car oil in all LS motors now?? The M1 webpage states "backwards compatible".
I have a few LS motors. LSA, LT4, L something in my work truck. I am considering this new oil now..
I'm surprised they haven't done that first thing. They know there's issues with some engines so warranty extension is mandatory at this point.The L86/LT1 didn't have any lower end issues, This is a embarrassing moment for GM!......First thing they needed to do is extend the warranty on ALL L87 engines!
Supercar isn't the only DexosR option: https://www.gmdexos.com/brands/dexosr/index.htmlThe question is: do you use this Super Car oil in all LS motors now?? The M1 webpage states "backwards compatible".
Are you saying GM is spending $10zillion dollars on recalls, oil changes, oil caps, and it's NOT going to help. !!!So, what's the consensus - will this viscosity help reduce failures?
Maybe. Probably not infant mortality. But good for long term ownership/engine life.So, what's the consensus - will this viscosity help reduce failures?
It should help get people past the warranty period....So, what's the consensus - will this viscosity help reduce failures?
Someone mentioned programming the variable pressure oil pump for the thicker oil.So, what's the consensus - will this viscosity help reduce failures?
Curious why they switched it to 0W-40 for the recommendation. Because the thin 0W-20 CAFE oil is contributing to the problem? Or might it be causing the problem? Crazy EPA regulations are being wiped away at a very past pace right now, and automakers see this, and probably are thinking..thank god we can finally stop caving to the government environmental crazies, and now we can recommend the oil we actually think is best for the engine. It may have taken a recall in this case, but watch how the oil recommendations start changing across many vehicles.The L86/LT1 didn't have any lower end issues, This is a embarrassing moment for GM!......First thing they needed to do is extend the warranty on ALL L87 engines!
He goes into what the issue is after reviewing the recall literature.
It's NOT "thicker oil is better". It's the crank clearances are too big, completely out of spec. and the heavier oil takes up the slop.What's funny, is cutting a page out of the owner's manual and replacing it with another page that recommends the 0-40!! This way the "trust the engineers" crowd can get their marching orders and feel good. Will they apologize to the ones that said thicker oil is better? Of course not - they never admit they were wrong - they just double and triple down.
Doesn't have to be the super car branded one exactly. I've been using whatever off the wally shelf euro 30/40 instead of 0w-20 in my new engines for years and they're still under pt warranty. Use whatever euro 30/40 oil. 40's are a touch thicker. I'm running 5w-40 in my escalade and outlander sport at the moment.The question is: do you use this Super Car oil in all LS motors now?? The M1 webpage states "backwards compatible".
