Yep. The bearings can’t tolerate 0w20 and/or low oil pressure.It's a bearing tolerance issue?
Both Kia and Hyundai are now recommending oils as thick as 20W-50 in many of their engines, that were originally stickered for all the water thin stuff. They've had to replace millions of dollars in engines because of it.
https://www.google.com/search?q=Kia...j33i299l3.32403j0j15&sourceid=chrome&ie=UTF-8
From the Motor Trend article:Yep. The bearings can’t tolerate 0w20 and/or low oil pressure.
But yeah, blame the viscosity.From the Motor Trend article:
"Specifically, the problem with the L87 6.2-liter V-8 appears to be related to two manufacturing defects that severely damage or outright destroy the engine (again, in 597,630 Chevrolet, Cadillac, and GMC trucks and SUVs).
One of the defects allows sediment to contaminate the connecting rods and crankshaft oil galleries and destroy rod bearings. The other is simply a crankshaft with surface defects and out of specification dimensions.
Unfortunately, the only way to know an engine is affected is when the engine begins making the wrong types of loud noises, the check engine light comes on, and/or engine performance degrades (including to the point of a no start condition) with a check engine light (CEL) popping on."
This tells me the oil is just a band aid.From the Motor Trend article:
If that’s a concern then use a 50-grade with a winter rating that’s appropriate for your starting temperature such as a 5W-50.Is the switch to 20w50 a real thing? That stuff is like goo coming out of the bottle and idk how well it’ll do in areas like where I am where we get a polar vortex or two each winter…. Not the OEMs problem I suppose if the vehicle owner doesn’t have a heated garage or a sump heater?
He goes into what the issue is after reviewing the recall literature.
Yowza.From the Motor Trend article:
Indeed. Plus it appears that manufacturing swarf is another one of their problems.This tells me the oil is just a band aid.
Always was going to be.This tells me the oil is just a band aid.
Funny but none of those problems are new or unheard of. And as you note none will be fixed with oil.
I am a GM fanboy.The range of impacted engines is what, 3-4 years? Why does it take that long to find 2 manufacturing issues?
The initial batch of LT1 for the 2014MY had a similar contamination issue.From the Motor Trend article:
so he will be on 3rd engine
I find it hard to believe we're only talking about 17,929 engines.
