Originally Posted By: billt460
Originally Posted By: hatt
Quote:
...engaged in the business...
You missed that part. You also can't buy a pallet of stripped lowers and turn them into complete guns to sell. You can assemble them for personal use. If down the road you get tired of it you can sell.
When you sell a gun you manufactured for profit you are, "engaged in business". Look, I don't care what you do or don't do. You can build a rifle from a 80% lower for your own use. It is perfectly legal to do so. You CANNOT build a gun on a 80% lower that is non serialized and sell it... Nor can you stamp a B.S. "serial number" on it, in some half baked attempt to make it legit to sell. That is engaging in firearms manufacturing without a license. That is illegal.
From the ATF:
Quote:
Individuals manufacturing sporting-type firearms for their own use need not hold Federal Firearms Licenses (FFLs). However, we suggest that the manufacturer at least identify the firearm with a serial number as a safeguard in the event that the firearm is lost or stolen. Also, the firearm should be identified as required in 27 CFR 478.92 if it is sold or otherwise lawfully transferred in the future.
More from the ATF:
Quote:
The GCA at 18 U.S.C. 923(i) provides, in part, that licensed manufacturers and importers must “identify”
each firearm manufactured or imported by a serial number in the manner prescribed by
regulation. Federal regulations at 27 CFR 478.92(a)(1) further require importers and manufacturers to
identify each firearm by engraving, casting, stamping (impressing), or otherwise conspicuously placing
the individual serial number and certain additional information - the model (if designated), caliber/gauge,
manufacturer’s name, and place of origin on the frame, receiver, or barrel - at a minimum depth. Section
478.92(a)(2) specifies that a “firearm frame or receiver that is not a component part of a complete weapon
at the time it is sold, shipped, or otherwise disposed of … must be identified as required by this section.”
I guess you're new to guns. If you had been around longer you'd know there are million of imported guns with horrid hand engraving by the importer.
The only real question is whether a non licensee would need to put any information on the gun to sell. "Should" isn't must.
From the ATF:
More from the ATF:
