I have read on countless forums how people employ the "Italian Tune-up" to blow deposits out the tail pipe. I have also read how high Calcium additives in certain motor oils may contribute to pre ignition while in low RPM/high load situations, which may also be affected by oil dilution. Wouldn't using the Eco function make things worse since it basically keeps you in that low RPM mode.
