I've already considered this...my plan if they come for me is to release a big synthetic oil slick to divert their attention while I slip away. Like a squid...quote:
They could take us all to the funny farm any day now.
Alex: Be careful, it's not that easy. The geniuses at AZ and Castrol have really created an odd situation. Castrol has 0w-30 that's US made, but comes in almost the same bottle as the German Castrol. Autozone compounds the problem by stocking the stuff interchangeably -- you must examine each bottle individually to make sure it says "Made in Germany". I've checked out about a dozen AZ stores between New Orleans (where I work) and Pensacola (where I live) and every one that had GC also had some US made 0w-30 bottles mixed in. Buyer beware. . .quote:
Originally posted by Alex D:
GC availability should absolutely be no problem anywhere in the US where there's a Autozone. just have the Autozone manager order it from their Castrol rep and Voila...there you go.
I am so far happy with my GC in the Suburban. just moved from Iowa to North Carolina and we pulled a 3500 lbs. trailer about 1200 miles going South through the hills of VA and WV.... so the engine and tranny had to work a little. On top of that, the ambient temps were around 88F so I am sure the oil got hot. The oil pressure retention even at those high temps was excellent!! On dino or M1 the oil pressure would be 5 lbs. lower at similar temps than with GC. The oil turned relatively dark after already 1000 miles, but I assume it was because of the pulling.
Will be interesting to see the UOA ... I will drop this oil at 3000 miles.
FYI, if you make it up to the Panhandle area, we've got GC all over the place. I've found it in a couple AZ stores in Pensacola, I've heard it's available in Fort Walton too, further east, I don't know. Moving west, there's plenty in New Orleans as well.quote:
Originally posted by dropitby:
I'm sure Castrol is a fine maker of oil but their marketing stinks. Not the catchey frazes,the product availability. No GC in FL anywhere I know of and if it's as good as the hype they should have it on a special rack like RL. No they hide it in a look alike bottle and why it may be their # 1 or 2 seller if they had any sence.![]()
