Gas Shok
Newport News, VA
http://usafuelservice.com/ethanolbasics.htm
has anyone used this for old gasoline?
It claims to boost regular to premium and absorb water.
Quote:
Add “GAS-SHOK”™ fuel additive, the formula contains state-of-the-art ingredients that safely absorbs water. Combining “GAS-SHOK”™ with ethanol fuels will prevent phase separation. We also add powerful lubricants so suspended water safely passes through the fuel system.
The heat generated during engine combustion separates the water back out of the fuel as steam. The steam boosts power, cleans engine valves and combustion chambers which prevents carbon buildup.
**This results in a clean and water-free tank and fuel system.
With “GAS-SHOK”™ engines produce more power and run smoother.
There are no negative effects and engine warranties are not affected!
Our unique proprietary formula also adds combustion enhancers so regular grade fuel is boosted to perform like premium grade. The savings more than pay for the cost of our additive.
And this here. If it really does work as they say it sounds better than anything else I have read about.
Quote:
Add “GAS-SHOK”™ fuel additive with advanced combustion enhancers that restores the fuel economy. Compared to untreated fuel, “GAS-SHOK”™ will produce a minimum gain of 10% in fuel economy.
This more than pays for the cost of using it!
In tests, we found we could blend “GAS-SHOK” with regular fuel and safely run it in most engines requiring premium fuel. There was no pinging, knocking or power loss. The engines are still running perfectly after using it for more than three years.
