Thanks. I was thinking of Fumoto butnot any more...s
Quote:
Imagine if that happened while crossing the Arizona desert or something! No thanks. How hard is it to remove a drain plug? I can get my hand out of the oil stream quick enough to only get a slight splash of oil on my hand. No biggy. That's what this is made for:
Quote:
You've got the jack&stands/ramps and drain pan out already, you have to deal with the oil filter which will likely spill a little anyways, how much trouble is it to bring a wrench?
Quote:
No quick valves here either. Drainplugs are too easy to use. Suredrain/Fumoto/... just add another point of failure.
Quote:
It's a pain to wrench the oil drain plug off and back on every time . . .
See if you can blow through it when it is closed.Quote:
Look through the opening of the valve, up towards a light, and cycle it opened and closed. See if you can see what is going on.
