While you are correct, I think that there is also more to it than that. The fuels that the drag racers use, alcohol and nitromethane, have a tendency to washdown the cylinder walls of oil very quickly. Partially this is due to the air fuel ratio that they run (on a passenger car it is 14.7:1 while they can run as rich as 1:2 which also goes along with the fuel dillution you pointed out) but is also due to the chemical properties of the alcohol which break up oil films. A thicker oil is used in order to stop this process from happening as quickly and ensure that there is some lubrication present at the rings.quote:
Originally posted by AEHaas:
Dragsters use the thickest oils as high as 70 wt. The reason is because of extreme fuel dilution from just one run.
aehaas
Perhaps someone can actually add the chemistry to the interaction, as my info is from reading and talking to racers who use different fuels. Or, maybe I am wrong and someone will prove it!
